Post your flame shots here!
Discussion in 'Stove Forum' started by presscall, Sep 21, 2011.
  1. SNOWGOOSE
    Hi Ian,
    Photo's of your Op 8R bnr in Trangia & Op 8R with Enders silent bnr……
    I don’t know how you achieved this unique conversion Ian but a great idea brilliantly executed.
    Rob
  2. linux_author
    haven't seen a Punker two-burner here yet, so:
    as seen on the lanai:
    burners at full throttle after prime:
    closer:
  3. redspeedster
    County Durham
    More
    Russian R8
    Pop can stove
    Swedish Mil burners one simmering.
    123r/mini cap in Sigg Tourist
    Juwel model unknown (top me anyway)
    OK not quite a flame shot but some cherry red for spuds ;) Primus 51 makes coffee.
    Chinese Kovea copy.
    Radius 42
  4. Ian
    Ian Subscriber
    West Yorkshire
    I had some adaptors made a few years ago to connect a 111 bnr (LH adaptor) & 8R bnr (RH) to a Nova hose.
    The 8R bnr seemed like the ideal size for the Tran 27 windshield set-up. A 111 bnr in there a la KAP Arctic would have been seriously OTT. Having joined burner to pump a simple strip of brass formed into an inverted top hat shape enabled the fitting in the Trangia. I put the Enders silent on it mostly because I had one and it fit; I don't think there's anything to be gained by using it. It is a relatively huge lump of steel which takes a fair bit of heating up. and putting a pan into the w/s over the bnr muffles the roarer to a satisfactory (for me) level. A Primus silent cap or one of Gary's would probably be a much better bet but I didn't have either at the time. I had hoped that with a shortened pump (to fit the Sigg 250ml fuel bottles) the whole issue would fit into the 27 for transport but the bottle/pump assy is just a little bit too long.
    I still have it and potter about with it every now and then.
  5. Christer Carlsson
    I have an old battered Radius No 20 which I use to boil my coffe on at the weekends, and here's a shot of it I took just the other day.
    I have converted it to a silent burner since I only use it indoors:
  6. presscall
    I tried out a set of loco7stove/kerophile's cast-iron flame plates tonight on a Primus 100, Primus 96, Thermidor.
    Primus 100
    Optimus 100 plate on Primus 100
    ... couldn't resist trying it out upside-down to see what effect that heavily dished top would have. It flared and the burner soon ceased to vapourise
    Primus 96
    Thermidor
    Converter silent cap on the Primus 100
  7. Michael1965
    Iowa
    Some stoves:
    Optimus 00L
    Svea 106
    Optimus 8r
    Svea 123r
  8. T-Bone
    Here are a few of my Svea 106:
    One of my Optimus 80 aprés fettle:
    Two from my Optimus 111T:
    Two from my Swiss ranger stove, one using a Trangia burner, and one using a Bio-Hazard stove:
    One of my mini-woodgas stove:
    And one because you said "flame shots". :mrgreen:
  9. Ian
    Ian Subscriber
    West Yorkshire
    A few more...
    Yet another 210'
    and from a different angle,
    that CS56 again,
    the Hydro,
    An 8R burning meths,
    Pr 70 with Primus silent cap,
    Another 123,
    A Pr 71,
    and a couple of M1942s,
  10. presscall
    Been playing with my Coleman Handy Gas Plant tonight, jet change (downsized) to burn kero.
    No 'instant lighting' on kero, so I had to pre-heat the generator/burner with a kero blowlamp.
    A gallon and a half of kero in the tank, pressurised to 25psi.
    Backed off a little from fully open on the generator control wheel, burning well
    Generator control fully open, overfuelling
    Simmering
    Close up
    Burner from above (quick snapshot - uncomfortably warm)
    Tank-mounted fuel/air valve on a quarter-turn, generator control full-on. Consequence, lean burn, flame lifting off burner
  11. RonPH
    Here is my contribution - Landers Frary and Clark Alcohol Stove
    Ron
  12. yonadav
    yonadav Subscriber
    Israel
    One of my favorites - Radius 42 with a brass coin used as flame plate (my avatar, too). 1316946599-IMG_5475_resize.JPG
  13. Sparky
    Sparky Subscriber
    Houston, Tx area
    Vintage 1930 Sears Cook Rite suitcase stove.
  14. linux_author
    hey! i'd love a bit more info on the 8r running meths!
  15. Ian
    Ian Subscriber
    West Yorkshire
    It's easy enough; I blanked off two of the big slots inthe 8R's bnr bell with heavy foil and fitted, IIRC, a 111T alcohol nipple. Meths likes loads of fuel and not much air.
  16. linux_author
    thanks! i assume a good prime and also perhaps a puff or two from a midi pump?
    edit: see there's no midi cap, so a simple prime works!
  17. aktopp
    aktopp Subscriber
    Norway
    Optimus No. 11
  18. aktopp
    aktopp Subscriber
    Norway
    Some stoves with the Special silent burner.
    From left to right:
    • Høvik Verk Standard No.36, Høvik burner
    • Optimus No.5, Høvik burner fitted by previous owner
    • Radius 21, Radius burner
    • Radius No.7, Radius burner
    First priming
    Then burning
    A pair of them a bit yellow, but who cares?
  19. presscall
    Ingenious, Yonadav. What's the coin you used?
  20. Ian
    Ian Subscriber
    West Yorkshire
    ... and the one that got away, atop a Svea 106,
    Thank you, Arne Kåre
