Prabhat, India. Garrett-Wade sales.
Discussion in 'India' started by John Paul Appleyard Green, Jan 21, 2017.
  1. John Paul Appleyard Green
    John Paul Appleyard Green Subscriber
    @Greeley - "All are welcome. Come into the light. Namaste."
  2. John Paul Appleyard Green
    @Greeley - My Prabhat goes back to Garrett-Wade tomorrow. Too bad. A pretty machine.
  3. presscall
    No problem. You're right, multiple lead washers would still de-laminate into separate shims after crushing. I guess I had in mind the bunch of them remaining in the mounting boss when the burner was removed.
    Seems a shame that of all potential manufacturing pitfalls - stress cracks in the fuel tank, pump end caps de-soldering, leaking fissures in inadequate brazing of burner components - it has to be something as basic as that to fall short on.
  4. donnecaidh United States
    Chinook, WA
    John, I received that very same stove from Garrett Wade today. After reading some others experience with these stoves I was beginning to think I had made a mistake. However, Mine showed up with presoaked leathers and fired up without a hitch. Maybe their learning that a little quality control goes a long way.(or maybe I got lucky) I will say it was nice to hear that old roarer. I haven't used this type of stove in over 40 years. I had a couple of the little square box type that always performed well. (well, almost always).
    This Prabhat is a little large for short treks, but would be worth carrying on longer ones. I'll likely pick up an old primus for short treks.
    I like reading your posts. You seem to know about all there is to know about these things. Thanks for your info. Good luck to you.
  5. Thelinks United States
    Texas
    I bought my first one of these yesterday off CL. The previous owner had a clue on how to start it but no clue on maintenance, cleaning, storage and troubleshooting. After taking it apart for cleaning out the varnish build up. I did found it also had a weep. The “gasket” between the riser and the preheat cup was toast. I found some high temp muffler wrap from the local hardware store and made a new gasket by pressing and cutting out to size. No weeps and this thing is awesome. Now that I have burned half a gallon of kerosene through it playing around I need to tear it down again to shiny it up.
