Here is a pack of cleaning needles manufactured by the Portuguese Manufacturer of Hipolito stoves: Best Regards, Kerophile
Hello Kero, I have had several Hipólito's passing my place as a set in more ore less complete state. Some of them even with the often absent spirit bottle, unfortunately not printed like Primus' but with a glued-on paper wrapper. But never have I seen this neat sachet from Portugal, and for many a collector these 'details' are the icing on the cake! Thank you for showing, regards, Mike BTW, this post will show it was edited by Dutchmike for reasons unknown. Point is, Dutchmike cannot file anywhere (?) why he decided some amends were in order. Ah, the good 'old' site, where getting older could be hidden discreetly...
Hi Mike, I had the same problem with my numerous edits when making a post. I then discovered that the "don't mark this post as edited" is "hidden" in the "Reason for Edit" blue box in the edit function. Interestingly the edit function in PTs remains as originally. Hope this helps. Thanks for you comments on the Hipolito prickers, you are right about them being the "icing on the cake". Best Regards, A Senior, George.
Hi Mike, you're not the only one searching for the "reason for edit" or "do not show post was editted" thingy! Regards, Wim See! No such thingy
