Primus 12a restored
Discussion in 'Stove Forum' started by Nicola Francesco Elia, Mar 11, 2022.
  1. Nicola Francesco Elia
    Italy
    Hi everybody,
    a long time ago I found a rare Primus 12a tank, full steel, with the center of the bottom plate completely rotten and heated by the rust. Many bits were missing, no riser and burner, no filler cap, no trivet supports and only a few bits of the original cast iron trivet.
    Here some images when I found it:
    02AE407B-7087-4677-BBCC-CD488F9CB22C.jpeg 96252E8C-61C5-4688-874F-3BB3BDDAF701.jpeg
    During the past weeks I started to hope to bring the stove back on fire, so as first thing I found an usable filler cap, some supports of the correct height and I managed to create a riser tube by soldering together some spare bits by broken stoves.
    A replacement Primus roarer for this model was the easiest part to find.
    Fortunately I then found an exact cast iron trivet as was the original, so this luck let me trust in this restoration.
    Then the worst part: the tank bottom.
    As said the center was completely rotten so I decided to cut a whole circular area eliminating the worst material up to the more solid steel. A couple of pin holes on one side of the plate needed to be fixed too.
    As patch I desoldered the bottom tank of a cracked 54 and with some scissors I have cut the patch, 1 cm larger than the removed area to allow a good wide area for the solder.
    Once cleaned the parts and tinned the soldering went very smooth.
    I tried to make a good looking fix considering the rarity of the stove.
    Well this is the story, this is the result:
    86C7757A-1E98-4A48-80D3-0E119F27F4F2.jpeg B426F050-A6E4-4E36-BCC8-F94BFDE463DE.jpeg 092F5A42-208F-4B4E-BB20-DF9E94BA664E.jpeg 67DC0CBC-378E-4405-B574-C2DC92B1F6BB.jpeg 381597ED-9766-4799-93BC-4E54FE331C3E.jpeg 561D0980-7217-4662-9D72-5DFCD66C7D95.jpeg 32DDE57A-DD16-46C0-981D-5BEF9C259151.jpeg A837AF70-0A55-4BC5-AFB3-1B86C23D1E65.jpeg D0D634B9-448C-4482-BFF1-F223B2A16181.jpeg 0CD64CCE-54CA-4090-903A-66E644E89064.jpeg 2120C2EA-1F7D-4312-895B-8BD3BF9E9C98.jpeg AEF1FC10-89EF-44E7-9545-BEDBF065C727.jpeg 3F7E47A6-6D36-421C-9420-C95687E7F63B.jpeg 7A30122C-3343-43EE-84B6-EE6A2A52F8AE.jpeg 8C724EAA-B86B-4ACA-897C-54EA91526E68.jpeg 3028361E-86F8-4536-9FC0-EFC2FA97D023.jpeg BE402468-E394-4530-9333-007E314D90BD.jpeg 42C0AE4B-B654-4613-A3B0-3D15A6F81B28.jpeg 9298A80C-A333-4FDF-9574-6DE04BEF6F0D.jpeg
  2. Nicola Francesco Elia
    Italy
    Additionally:
    for a long period I have been thinking about the originality of this rare stove.
    Was cutting part of it the right thing to do? Better leave it as a relic?
    Then I realized that repairs are part of the history of these stoves so I decided to proceed and be part of its long history of almost 115 or more years. In the end I did a good thing because the stove now works again.
    Next steps:
    Find a correct filler cap (it should be the early one with the stove designed on it)
    Make a new riser identical to the original.
    Nicola
  3. CW
    CW United States Subscriber
    thank you for rescuing it well done
  4. ROBBO55
    Nicola, that is a very neat repair :thumbup:
    Good luck finding the missing original components.
  5. Nicola Francesco Elia
    Italy
  6. Tony Press
    You should be very proud of your repair! Excellent work.
    Best regards
  7. Nicola Francesco Elia
    Italy
  8. Dave1000car
    Dave1000car Ireland Subscriber
    Ireland
  9. Nicola Francesco Elia
    Italy
  10. igh371
    Durham
    Fabulous and challenging restoration, and well worth it for such a rare stove. You have done absolutely the right thing.
    Ian:thumbup:
    @Nicola Francesco Elia
  11. Nicola Francesco Elia
    Italy
    @igh371
    Hi Ian, thanks, I really appreciate your message!
    Nicola
  12. hikerduane
    Plumas County, CA
    Wow! Very nice fix and result, thank you for sharing.
  13. multi-cho
    multi-cho Korea, Republic of Subscriber
    Korea/seoul
    The work of a great orthopedic surgeon.
    It was the right prescription.
    I saw s healthy stove completely restored.
    I'm feeling good!
    You did a really good job !
  14. Nicola Francesco Elia
    Italy
    @multi-cho
    Ahahah thanks! The patient needed only 1 minute of pre heating therapy to return to run again :)
    Nicola
