Primus 210 meets Trangia
Discussion in 'Stove Forum' started by Sternenlicht, Aug 26, 2020.
  1. Sternenlicht
    Sternenlicht Subscriber
    Hürtgenwald
    I combined a Trangia and a Primus 210. I hope for more efficiency due to better wind protection. I made it just 'quick and dirty' to test it with some spare materials in my shed.
    It was important for me, not to destroy one of them.
    I did not compare the time to reach rolling water, but I think it is a liitle faster than without the Trangia.
    First I was concerned about the air supply, but after boiling there has been no soot on the pot. So there seems to be enough air.
    Ciao, Bastian
    IMG_20200826_171138.jpg IMG_20200826_171323.jpg IMG_20200826_171341.jpg IMG_20200826_171317.jpg IMG_20200826_171348.jpg IMG_20200826_171453.jpg IMG_20200826_171459.jpg IMG_20200826_171504.jpg IMG_20200826_171729.jpg IMG_20200826_172429.jpg IMG_20200826_172434.jpg IMG_20200826_172458.jpg IMG_20200826_172547.jpg
  2. Doc Mark
    @Sternenlicht ,
    That's a great idea, and it appears to work a treat!! Brilliant work, and I'm glad you gave this a try! Thanks for sharing the results here, too! Take care, and God Bless!
  3. Twoberth
    England
    Very clever construction.
    Well done!
  4. SveaSizzler
    Tucson, Arizona
    The Hillary Everest Expedition did something similar with Primus 210s. They didn't use Trangias, though.
    There is some documentation in the Stove Gallery, I think.
    Anyway, very clever mod.
  5. kerophile
  6. SveaSizzler
    Tucson, Arizona
    Looks like something an enterprising tech sergeant would rig for a still.
  7. The Warrior
    Illinois, USA
    Nice work!
  8. kerophile
  9. BradB
    Central North Carolina USA
    It is interesting to me that after testing the Everest expedition chose a silent burner for those rough conditions. I was under the impression that here at CCS people consider the roarer burner more suitable for camping and that the silents are for domestic use. There must be more to the story. I saw where the silent burned well to a hypothetical 40k feet of altitude but the roarer was only good to 15k.
  10. ROBBO55
    Nice work @Sternenlicht . :clap:
    Have you tried it outdoor in a strong wind?​
  11. SveaSizzler
    Tucson, Arizona
    Maybe there are drawbacks to a roarer stove in high avalanche country?
  12. Spiritburner
    Apparently the silent worked better at high altitude - protected from wind of course.
  13. Sternenlicht
    Hürtgenwald
    Thanks for the links, I knew these setups before and they inspired me to make this.
    I did not test it yet in strong winds.
    A disadvantge of my setup is, that it makes the stove louder. The upper windshield acts like a resonating cavity. I have the same with my Nova in the Trangia.
    Ciao, Bastian
  14. Lemming
    Scotland
    Regarding silent burners, this is from the Royal Geographical Society's "Hints to Travellers", Eleventh edition, Vol two, 1938:
  15. Sternenlicht
    Hürtgenwald
    @Lemming
    Quite interesting document! But why they were not satisfied with the roarers?
    Ciao, Bastian
  16. BradB
    I read elsewhere that the roarers did not burn well above 15k ft.
  17. Twoberth
    England
    Since the roarer and silent burner are essentially the same in the way they mix the air and fuel prior to the gas mixture reaching the burner top/caps, I would be interested in why the silent burner responded to the special nipple and not the roarer.
  18. TRA_A Israel
    NI
    Similarly, I wonder why no commercial company has essentially put height adjustable legs on a 27 upper windshield (no heat deflector plate like above so that air updraft cools canister as designed) for use with any modern resealable canister-top lpg stove: or would it still make the corporate lawyers nervous?
  19. Sternenlicht
    Hürtgenwald
    @ROBBO55
    I tested the stove at quite windy weather, but it didn't work that good. It was still sensitive to wind.
    I changed the original wind guard against a closer one, and it works much better!
    Cooking in stronger wind without aditional screen is possible.
    Ciao, Bastian
  20. ROBBO55
    Thanks @Sternenlicht , I thought there might be a problem. The new modification looks more wind proof. :thumbup:
    It's been an interesting post to follow. :)
