Primus Alcohol Fuel Conversion Kit. No.4416. 1942
Discussion in 'Stove Paraffinalia' started by igh371, May 9, 2026.
  1. igh371
    Durham
    The kit was supplied with the 4 components wrapped in the information sheet. Persuading the sheet to lie flat to photograph wasn't easy after some 60-70 years in storage!
  2. ROBBO55
    Thanks, the length of the brass mesh is interesting.
  3. Sellig33
    Hi @igh371
    Could you provide us with a drawing of the restrictor tube showing its various dimensions? Also, could you indicate the size of the jet orifice?
    Best regards.
    Gilles
  4. igh371
    Durham
    @Sellig33 the restrictor tube dimensions are length 42mm, o/d 13mm, and the holes are each 4mm diameter. I don't know what size bore the jet has, but the correct jets are still readily available from the usual outlets under the later Optimus part number 2508.
  5. Sellig33
  6. barrabruce
    barrabruce Subscriber
    Australia
    I presume the mesh is to help subdue the pulsing.
    My 111T choofs away and self pressurise the tank.
    I tend to add about 10% of water to the metho in the tank to cool it all off some especially when baking with an Omnia Oven.
    One day I will make a riser so the reflected heat isn’t so fierce.
