Primus model 2063
Discussion in 'Fettling Forum' started by joelman79, Jun 16, 2005.
  1. joelman79
    I have a primus model 2063 propane 2 burner stove. The burner furtherest from the bottle have very poor fuel flow (it won't even light). Is there a way to clean it and make it work?.
    Thanks....
  2. Nordicthug
    Nordicthug R.I.P.
    All the propane stoves I've ever had anything to do with were simple in the extreme. I suggest you take the srtove apart as far as you can (being very careful not to get parts jumbled) then blow fairly high pressure (80-90 PS)I compressed air backward through the jets and feed tubes. Blowing out the burner heads as well might be helpful. Other than this, I don't know what you might attempt.
    Gerry
  3. Susan Gresia United States
    Olympia Wa
    Hello-I just brought a Primus 2063. Its in great shape but does not have the hose and regulator. Does anyone know what I should use to connect to a small 1 lb propane tank or green propane bottle
  4. Lennart F
    Lennart F Sweden Subscriber
    Vänersborg, Sweden
    The US version of 2063 is Primus 2048 and the 1" bottle valve on the hose is the only difference - standard propane hose fitting from bottle valve to hose.
    Primus 1960's style quick connection that is slightly different to the ones Primus use today - is the thing you really need and that could be fitted to a new propane hose in similar size.
    Observe that this stove operates with full pressure propane without regulator.
