Pump bucket nut removal trick
Discussion in 'Fettling Forum' started by Big BTU, Oct 21, 2010.
  1. Big BTU
    For those frozen on pump bucket end nuts that are on all the brassies and the old 111 etc, I use a couple thick rubber bands wrapped around the shaft of the pump very tightly.
    This allows you to grip the pump with pliers or vice grips without damaging the metal. The metal is held in place by the rubber bands traction.
    Works great for me. I hope this helps and has't been covered in another post.
  2. BernieDawg Banned
    Heya Jon
    Good on ya mate for protecting your shaft with good quality rubber. :thumbup:
    I use old truck tire inner tubes for the same purpose. Usually can get 'em free for the asking at the local tire shop. Or, there's always dumpster diving after they close I suppose..... 8-[ :whistle:
    Gary
  3. hikerduane
    Plumas County, CA
    Thanks,when I get my leather cups from Sefa I'll know what to do.
  4. Big BTU
    Hey Gary only the best quality for my shaft :D/
  5. anlrolfe
    Louisville Kentucky, USA
    I guess you can do similar with leather wrapped around the shaft? Baah
    AR
  6. parable
    i needed that hint for today. worked perfectly. thanks. hank
