Rebuilding Coleman 457 Handy Plant Guage
Discussion in 'Fettling Forum' started by 1bluedevilfan, Sep 4, 2006.
  1. 1bluedevilfan
    Greetings,
    I've just completed refurbing a Coleman 457. What a stove ! The pressure guage was a wreck, but has been brought back to life. Thought others would enjoy the results and the procedure.
    The ring securing the glass could not be loosened. Used a Dremel tool with fine cutting wheel to score the ring being careful not to cut through. Used a flat blade screwdriver to break the ring and remove. The rest was careful cleaning and painting.
    Used Rustoleum Rust Reformer Primer which converts any rust to a stable compound. The matte black finish is perfect.
    Wired the ring back to shape using fine copper wire and silver soldered using 56% silver. Filed to shape and you can't locate the repair.
    For those interested, Vulcan's Workshop on eBay is a great source for silver solder and the all important Hi temp flux to repair iron, including cast iron. http://stores.ebay.com/Vulcans-Workshop
    Bud
    BackRebuiltHandyPlantGuage.jpg [/img]
  2. Ian
    Ian Subscriber
    West Yorkshire
    Very neat indeed.
