Rusty but Running
Discussion in 'Stove Forum' started by Blackdog, Jan 1, 2024.
  1. Blackdog
    Dreaming of snow
    Hi Rodger, great old Radius to add to your 'discus' collection. I've a Primus 96 with a similar air screw bodge- it works well as there's also a tiny piece of packing popped in first as a seal. I haven't the heart to fit a 'proper' replacement air screw! I'll add it to the thread when I get a chance, I've been meaning to for months.
  2. Rodger Willows
    Rodger Willows Subscriber
    Tasmania
    @A A C
    Thanks! I’ve got some pot support legs off another Radius Ltd (sadly with multiple stress cracking) to fit it out - when I’ve re-soldered the leg mount.
    @Blackdog
    Looking forward to seeing your Primus No. 96 Chris!
  3. Rodger Willows
    Tasmania
    I picked this up yesterday in Brisbane, QLD:
    You may notice the rather "jaunty" angle of the riser and hence burner. There is also evidence of copious previous soldering:
    "K.F.E. ESKILSTUNA SWEDEN M.F.A.B." - I think!
    "THE BEST STOVE IN THE WORLD":
    I am unsure of which model it would be under the patina!
    The images that alerted me:
    (Another) Primus 4155 regulated burner...
    Previous discussion here:
    Primus Part No.4160 for No.4155 Burner
    Pricker functioning properly:
    This afternoon I "cold-set" the riser and fettled the stove. The pump rod was "cactus", but I'd accumulated a suitable replacement.
    It was then time to fire it up:
    There is a height discrepancy between the outer cap of the burner and the pot legs, which necessitated use of a cast iron pan ring to raise the kettle sufficiently:
    It performed well:
    Minimal rotation of the spindle produced a gentle simmer:
    No "sooting":
    Thanks!
  4. Tony Press
    Great find! KFE stoves are top class, as is the Primus burner.
  5. Blackdog
    Dreaming of snow
    Great post @Rodger Willows, I'll never tire of the display of coloured flames as an old burner comes back to life! This KFE must have led a hard working life with the usual repairs to all the weak points.
    'The best stove in the world' is open to debate, but for somebody this was quite possibly the only stove in the world, and had to keep working no matter what.
  6. Knee
    Poland
    I am preparing this stove for the reference gallery, but I thought that at this stage it could be posted in this thread.
    This is an early Radius No. 6, which is not yet in our gallery. There is still some work to be done on it before I get it in order.
    I have seen all kinds of wonders inside tanks, but this is the first time I have encountered a wasp/bee nest.
    After replacing the necessary parts and decoding the burner, it lit up quite nicely.
    IMG_20251015_203310478.jpg IMG_20251015_193310151.jpg IMG_20251016_190108834.jpg IMG_20251016_203722573.jpg IMG_20251016_190034127.jpg
  7. Rodger Willows
    Tasmania
    @Knee
    Great work!
    Those “UFO” burners are impressive - I haven’t yet encountered one in person…
    I look forward to seeing the fully-fettled result in the Reference Gallery.
  8. Knee
    Poland
    Thanks Rodger.
    Actually, I still need to solder the legs, which involves cleaning and removing the patina.
    The engravings seem to be quite deep, so there is a chance that cleaning will not adversely affect their quality.
  9. Knee
    Poland
    I recently picked up this little stove for next to nothing.
    I still don’t know where it came from.
    I don’t know if the layer of soot is hiding something, but the burner has no markings.
    Maybe it’s just another no-name stove?
    Some parts of the pump suggest it’s fairly new. I replaced the pump diaphragm and the O-rings so I could check for leaks. The filler cap gasket needed replacing. Other than that, everything’s tight.
    I fired it up. The color of the flames doesn’t look clean.
    I’ll work on it some more when I have a free moment.
    IMG_20260327_064736274.jpg IMG_20260327_064752654.jpg IMG_20260327_064929717.jpg IMG_20260327_064844958.jpg IMG_20260327_065435520.jpg IMG_20260327_070735689.jpg IMG_20260327_105206516.jpg IMG_20260327_195044903.jpg IMG_20260327_195722194.jpg IMG_20260327_195759013.jpg
  10. Rodger Willows
    Tasmania
    @Knee
    A new nipple/jet and you’ll have it “cooking”!!!
    Appears similar to a Primus 210?
  11. Knee
    Poland
    Hi @Rodger Willows .
    That’s the size, and that’s how I saw it at first, too. But that’s not it. Maybe I’ll figure something out someday...
  12. Scott B
    Scott B Australia Subscriber
    Tasmania
    Hi All
    In this episode of Rusty but Running....
    I present an S stamped 1928 Primus 704.
    Unfortunately found without its stand and smelting pot.
    An interesting but well made pressure release valve installed.
    I had a flame tube cut at our local brass works, It is longer than original at 80mm but wanted it that way to allow adjustment if needed.
    1000022691.jpg 20260226_165934.jpg 20260313_194657.jpg 20260313_195244.jpg 20260313_195901.jpg Screenshot_20260409_165106_Gallery.jpg
    It took alot of preheating to get up to speed.
    Needs work still.
    It will receive @Rodger Willows boil up method to clean up and retain patina.
    Happy with the performance.
    Kind Regards
    Scott B
  13. Rodger Willows
    Tasmania
    @Scott B
    A very impressive performance!
    Great work!
    I look forward to seeing it in the SRG…
  14. Blackdog
    Dreaming of snow
    Great sequence of photos @Scott B, big beastie! A lot of these old furnaces really took a hammering in use, true to form this one has had some repairs.
    Now was the 'proper' air release screw lost in use, or is that a deliberate extension to avoid 'Primus' being painfully imprinted on finger and thumb when a long session of work was finished?
  15. igh371
    Durham
    DSC00669.JPG Prompted by need to check some details to compare with @Håvard Kvernelv's excellent new 1897 Primus No.6 gallery post, here is my long neglected spare same date Primus No.6 fired, for first time in decades. Remarkably the only new parts required to achieve this firing were a new burner washer and a filler cap seal! Not bad for a rather battered and care worn 129 year old.
    The resultant afternoon coffee and biscuits went down well (@Rangie:thumbup:)
  16. Tony Press
    Excellent!
  17. Blackdog
    Dreaming of snow
    There's some real 'needs must' solder repairs there!
    It's remarkable really how often these early Primuses can often be returned to action with very little work, as well as their inherent repairability with plumbers solder and copper bit.
  18. logen
    logen Norway Subscriber
    Brandbu
    Bought this one just the other day. A beast of a stove, Radius no. 36. Luckily I had a proper size flame ring in my parts bin. Fired up nicely, didn't even have to change any washer or oil the pump leather.
    Preheat with a nice new flame ring.
    No idea what was on the tank, but I burned hot.
    Shooting star Radius 36.
    Best regards, Vidar
  19. Rodger Willows
    Tasmania
    @logen
    Vidal, Great job - impressive monster!
  20. Blackdog
    Dreaming of snow
    Beautiful @logen, burning well and really kicking out the heat.
    The bigger the shooting star, the better!
