Hello, good morning friends Yes, I opened the burner, there was no obstruction, but I did not dare to touch the graphite washer. Considering that there was an iron net, it is not possible to install another net
@Nicola Francesco Elia @gieorgijewski Hello, I did the steps you said, but there was no change, still the flame had its pulse. I thought the problem was with the silent part, I removed it and installed the star flame, the roar of the demon was very loud and the same beat of the flame could be heard.
@Nicola Francesco Elia No, unfortunately, spare parts are not available and the nipple is too big. The nipples in the stores are too small and won't fit this oven unless I buy another oven for another $100 and swap the nipples, which is a problem for me. We should leave the stove alone and love her as she is
Ahahah nipples, jets, heads… I am still unsure how should we call them The pulsation happens also at lower pressure? Are you using gasoline right? Nicola
Yes, I use car gasoline, but we can buy Super gasoline, which has better quality, from the gas station and test it, maybe it will work. In a weak flame, the pulse becomes less The first time I pumped three times and the next time I added 3 more pumps but each time the pulse continued.
imo problem is with liquid flowed thru gas generator moved by bulb in riser tube this bulbing working as fuel pump inside the riser bulbing in the riser is the signal of boiling fuel in the riser possibly to high temperature of the riser or and - unclean gas generator surfaces and all internal tank surfaces ------------ decrease riser temperature is possibly by heat resistant seal in burner - tank point but first by me will be cleaning tank, generator inside, and mesh
Your Super Gasoline probably has a higher octane rating than the gasoline you were using before. Higher octane is achieved by adding substances to the gasoline which prevent knocking in high compression automobile engines. But these substances will not burn properly in a camp stove. You should use the cleanest low-octane gasoline you can find. ….Arch
@gieorgijewski Hello, thank you, I don't understand most of your technical words and I try to translate them. For example, a lamp in your words means a lamp that is 220 volts and is used for room lighting. This exchange of information between two languages from two countries and the Google Translate program creates problems. And it becomes difficult to understand the content I will check all the steps again Hoping for good days and calm and good ovens
@ArchMc Hello, thank you for your attention, there are only two types of gasoline in my country Can I experiment with kerosene, maybe the pulse will go away, not a good idea? Or should I test diesel fuel for heavy vehicles?
I try to semplify: clean perfectly the tank and the feeding tube from tank to burner, clean mesh into burner. Use high quality gasoline, not automotive one. Nicola
@Nicola Francesco Elia Hi, I reconnected the star flame player. Please listen to the video carefully. It sounds like something like a cleaning needle is moving and making a noise inside the oven. It's like someone is knocking softly on the door and it's stuck behind the door آپارات - سرویس اشتراک ویدیو
re your "We should leave the stove alone and love her as she is..." i hope you stick with this one. gieorgi sees problem, continue efforts to solve problem. my recall is auto gas use was fine for these. ANY use of auto gas it must be fresh (to view the fuel pour it into glass, let it settle, if it is suspect) and burn through the auto fuel completely (consider it to have zero shelf life ESPECIALLY in hot climates). burning a small amount of clean white gas through it (after a month / a session with auto gas) would be helpful. of all your postings, imo, this shmel is as good or better a fit for you as any of the others. i appreciate your views, i read and like to see all your posts / comments btw. good luck
@OMC Hi dear friend Thank you for following the content carefully Yes, as you said, I really like the Shmel Russian gas stove because it turns on quickly, it is very strong and excellent, and it works with a good and slow flame. Detachable pump structure is a good idea I hope that with your help, the problem of pulsating gas stove will be solved. Be happy and cheerful. By the way, what type of gasoline are white gasoline and automatic gasoline? In our country, car gasoline is green
