Sigg fuel bottles
Discussion in 'Stove Forum' started by MTCamper, Mar 30, 2010.
  1. MTCamper
    I finally found my old Sigg fuel bottles. One dark red and one plain aluminum, both in perfect condition (except for the gasket). I plan on replacing the gaskets with o-rings. What is the purpose of the two holes drilled into the threads of the caps and is it a concern if the o-rings partially block those holes?
    Lonnie
  2. parramethtrol
    parramethtrol Subscriber
    the holes are so that you can pour fuel in a semi controlled fashion without needing to remove the lid, but the pukka sigg pouring spouts are better imo
  3. MTCamper
    Thanks.
