Small tube
Discussion in 'Fettling Forum' started by fjildman, Mar 27, 2024.
  1. fjildman Netherlands
    Netherlands
    Hello,
    The small tube in the picture came with a Radius font. Could someone tell what it is? Where to mount it? Is there an English word for it?
    Thank you!
  2. Ed Winskill
    Igniter. Big end in the prime cup, other end near the jet. Held by the clip.
  3. fjildman Netherlands
    Netherlands
    Thank you for your reply, Ed. Much appreciated!
  4. Ed Winskill
  5. fjildman Netherlands
    Netherlands
    Should the igniter be completely hollow, I mean empty, or is a kind of wick required?
    Thanks again!
  6. nmp
    nmp SotM Winner Subscriber
    @fjildman
    There should be some wick in the fatter end be careful if it’s original it could be asbestos. So take care of you remove it.
    Nick
  7. Blackdog
    Blackdog Netherlands SotM Winner Subscriber
    Dreaming of snow
    @fjildman originally the base and sometimes part of the tube was packed with asbestos. Replacement is tricky as woven fibreglass rope doesn't allow sufficient capillary action. I've had mixed success with looser strands of glass fibre.
    They make any stove easier to light, saving the need for a second match if the flame does not catch before the priming flame burns out. And in the case of silent burners, they are even more useful as they light the burner from above once the flame below has burned out. Primus included them as standard on many models from the late 1920s(?) and certainly the 1930s. Some other manufacturers supplied them too.
  8. fjildman Netherlands
    Netherlands
    Thank you, Nick.
  9. fjildman Netherlands
    Netherlands
    Thank you, blackdog. Much appreciated!
