Storage life of Lpg cannister stove seals:
Discussion in 'Stove Forum' started by TRA_A, Aug 29, 2026 at 3:01 PM.
  1. TRA_A United Kingdom
    NI
    I have a Brunton stove base converted into remote stove as described
    In MYOG - A Winter Canister Stove using your Summer Upright Stove and the Brunton Stove Stand - Backpacking Light
    But minus the heat shunt. It was converted to a Trangia gas converter but as has only beeb used briefly to test then shelved fir several years.
    I wondered if the (synthetic presumably) cannister / hose seals have a storage life:
    If unused/lightly used to they last indefinitely or should one replace cannister stoves (or their seals) every X years irrespective of use.
    I
  2. snwcmpr
    Link requires membership
  3. Marc
    Marc Subscriber
    Oregon, USA
    Yep article is paywalled.
    Also yes, keep an eye on rubber parts perishing due to age. Won't be frequent, 10-20 years, with some rubber and fuel combinations failing almost immediately while others will be fine 30+ years later. As before, keep an eye on things.
    In automotive applications it's understood that rubber components and exhaust systems continue aging, whether they're used or not. Many timing belts have a calendar age replacement schedule as well as a mileage interval for this reason.
  4. TRA_A United Kingdom
    NI
    Thanks.
    Nb There used to be a non paywalled version on bushwhacking.org but I couldnt find it anymore
