Stripped screw on Coleman 530
Discussion in 'Stove Forum' started by Andrew Johanson, Jan 11, 2022.
  1. Andrew Johanson United States
    Marietta, GA, USA
    Thanks, @snwcmpr
    I understand your point and the importance of patience. In this case, however, the screw has nothing for the driver to grip. So even after the penetrating oil does its job, I still have to bust out the screw most likely (if the ScrewGrab doesn’t work). I have 4 replacement screws ordered from OCP luckily.
  2. Jim Lukowski United States
    New Jersey, USA
    That screw doesn't look far off from one had to deal with on a 530. It was stripping like that, but I didn't want to give up and penetrating oils weren't working for me. I took the stove to Lowes and got the largest blade screwdriver they had that filled the slot. With it, I was able to grab enough of the screw to remove it, but it still required patience and downward force while unscrewing.
  3. Andrew Johanson United States
    Marietta, GA, USA
    Thank you, @Jim Lukowski
    I have the largest screwdriver that will fit. Ha. Built for engine work. The ScrewGrab product should arrive on Friday, so I’m hoping for the best.
  4. 8R Pete United States
    New Jersey
    You don't want to hit the area too hard, or the fount will easily dent. I have a 530 that had a screw like that and have a dented fount as a result. I took a dremel tool and cut a groove in there and removed the screw that way.
  5. Majicwrench
    Majicwrench Subscriber
    The Seafoam will fix it!
  6. Andrew Johanson United States
    Marietta, GA, USA
    @redspeedster
    Thank you for suggesting ScrewGrab!!!
    Andrew: 1
    Stripped Screw:0
    This stuff really works!
    Now, I’m going to install the 4 new screws I received today from OCP. They also came with lock washers too.
  7. Jim Lukowski United States
    New Jersey, USA
    Compare the length of the old and new screws in case you need the washers to prevent the screws from punching through the tank/fount.
  8. Andrew Johanson United States
    Marietta, GA, USA
    @Jim Lukowski
    Thanks for the advice. I screwed them in with the washers, before I read this. Next time I disassemble the stove, I’ll check. :lol:
  9. hikerduane
    Plumas County, CA
    Cool!
