SVEA 123 age?
Diskussion i 'Stove Forum' startad av jdlsc, 12 mars 2019.
  1. kerophile
    23 september 2004
    14.341
    Från:
  2. Laitch
    Laitch Subscriber
    21 december 2010
    176
    Prickers. Is that better? :)
  3. Doc Mark
    12 december 2004
    19.659
    Från:
    @Rob McMillan ,
    You have some great info, already, but here are two photos that show a Max Sievert folding pricker, and the measurement of it's "prick(er)". Sorry, I couldn't help myself!! :oops::whistle::whistle:O:)O:):lol::lol:
    You will see that there is some leeway in this sizing, as other info gives slightly different info. I am sure all of it will end up giving you what you need! Good luck, and have fun! Take care, and God Bless!
  4. Rob McMillan United States
    11 juli 2018
    23
    Från:
    Ohio, USA
    Thanks Doc. I read another post about using guitar strings, went upstairs and found that my high E string was what felt like a perfect fit. That’s .010 gauge. Which is 10 thousandths? Whatever that is, I have many feet of it if anyone is in a bind for jet wire!
  5. Rob McMillan United States
    11 juli 2018
    23
    Från:
    Ohio, USA
  6. Fettler United States
    9 mars 2019
    1.294
    Från:
    Ioway
    I found that a medium set of acoustic guitar strings, the 1st or high E is still too thick. .013" or .33mm, at least for the Svea.
  7. Rob McMillan United States
    11 juli 2018
    23
    Från:
    Ohio, USA
    Based on collective feedback and prior posts I’ve seen, a guitar string of .010, or the high ‘E’ in a light set of strings is ~.0259mm and the next string up (‘B’ string) is .011, or ~.0279mm. Doc’s stove wire measured at .0125, or just under ~.032mm. The .013 medium guitar high ‘E’ string comes in at ~.033mm.
    Some stoves have larger nipples. That high E worked for my svea 123. YMMV!
    Thanks
    Rob
  8. snwcmpr
    16 november 2011
    22.077
    Från:
    Using a smaller pricker, you end up with a smaller hole.
  9. Rob McMillan United States
    11 juli 2018
    23
    Från:
    Ohio, USA
    I’ve read that they wear to a larger size over time. This is the first I’ve read that they clog to a smaller size. I get the concept. Have you seen it happen? And what’s the stock opening for a svea 123? I
    Couldn’t get the .0279 ‘B’ string to go in.
  10. Rob McMillan United States
    11 juli 2018
    23
    Från:
    Ohio, USA
    Or was that a joke and it’s too late for this old brain to get it! If so, sorry Snwcmpr!
  11. snwcmpr
    16 november 2011
    22.077
    Från:
    No humor, I think it best to use the pricker closest to the hole size, but not bigger.
  12. snwcmpr
    16 november 2011
    22.077
    Från:
    And ... the wire should be straight.
    This is a steel wire going into a brass jet. Obviously, if bent, it could cut the sides of the hole more than the straight one would.
  13. Simes
    Simes R.I.P.
    26 juli 2004
    4.539
    Från:
    Intended or not it made me chuckle. :)
  14. Tony Press
    8 juni 2013
    10.858
    Från:
    I usually use, for the 0.23mm jet, a 0.20 high E steel guitar string. For a 0.32mm jet, I have plenty of prickers.
    The 0.20mm wire works well on those jets between 0.23 and 0.32.
    Avoid a pricker that shaves the jet.
