Svea 123. Not enough pressure?
Discussion in 'Stove Forum' started by Quick Cal, Oct 25, 2020.
  1. Radler
    There are some strange advises in the net, what to do when travelling by air, with a stove. Some days ago, I have read to fill the fount with salad oil! If there is a unsuitable liquid in the wick (even water) it will not work properly any more.
    Radler
  2. Quick Cal
    Quick Cal United States Subscriber
    Mid-West
    Where can I get the pentagal wrench. Or what ever it's called.
  3. snwcmpr
    I would not light it without a jet.
    That is a problem.
    Long debated here. Many threads about that.
    Make one is the easiest way.
    Sometimes a good tool is up on eBay made by Varga???.
    Do not use the quietstove tool. It will damage your cap.
  4. SimonFoxxx
    SimonFoxxx Subscriber
    New Zealand
    I have a 1966 SVEA 123, and I can tell you that sometimes it runs amazingly well, and sometimes crap! I have taken out the wick several times to check it, and found nothing of note. It always pays to prick the jet, and maybe ream out the jet opening (very gently) with a drill bit (1/16) to get a good flame.
    Simon Foxxx
  5. threedots
    threedots New Zealand Subscriber
    Hello @Quick Cal . That black blob indicates to me that you may have some type of foreign residue in the wick that dissolves as the fuel passes through and then collects at the jet aperture or the original wick may have been replaced at some stage with another that may not be 100% cotton and may contain polyester.
    Try replacing the wick with one that is known to be 100% cotton. John
  6. snwcmpr
    Do you drill the hole out to .062" (1/16") or do mean cleaning the top of the hole?
    You may have a foreign substance that using it might clean up. Or replacing the wick might be needed. I would use it A LOT and see if the problem persists.
    Ken
  7. Quick Cal
    Mid-West
    So I've ran it 6 or 8 times after flushing the vaporizer. I lit it with out pricking. Seems to be working fine so far. Thanks for all the help.
  8. snwcmpr
    Good news.
  9. Ed Winskill
    Now that you've got 'er going, another useful tip: on the trail, when you've finished cooking dinner and the stove sits overnight, open the fill cap to equalize the pressure, or it won't work.
    Most times you'll refill before then but sometimes not. I had to learn that one.
  10. SimonFoxxx
    New Zealand
    Hiya Team and Mr Snow Camper,
    I use the drill bit to gently clean out the top of the jet, and not to go right through the jet. I suspect that pricking sometimes leaves a small burr, which distorts the flame pattern. The flame appears lopsided or wonky, and a gentle ream, one or two gentle turns of the drill bit remedies the problem.
    Simon Foxxx
  11. snwcmpr
    Very good. I took the word ream literally.
  12. Fettler United States
    Ioway
    I have to say I've never had to "prick the jet" over the course of many years on my Svea, though I sure wouldn't want to be caught in the field without one, because there is No Substitute, not as a practical matter. I keep one filched from an MSR taped to the underside of the tank. A light gauge high "E" guitar string will work in a pinch.
  13. Majicwrench
    Majicwrench Subscriber
    I have pricked the jet on mine in the field, but very seldom. If this was my stove I would be pulling wick, I would never trust it out in the woods. A stove that I have to mess with before I get me hot coffee or dinner is not welcome in my camp.
