Svea 123 Questions
Discussion in 'Stove Forum' started by Edward429451, Dec 12, 2018.
  1. snwcmpr
    @Tony Press idea is good. I am not sure that he uses gas, or just alcohol to prehet. Try preheating twice.
  2. Rob McMillan United States
    Ohio, USA
    Will work on the warm up aspect and report back. Thanks much.
  3. Tony Press
    I use 95% ethanol to prime my Svea 123s. The wick concentrates the heat closer to the burner. In the temperatures I usually use them one heat is enough; very cold I’d use two.
    They always get to helicopter speed quicker with a pot on top and out of the wind.
    @Rob McMillan @snwcmpr
  4. JP2
    JP2 Subscriber
    Canada
    Or it may be plugged between the valve and under the nipple.
    Remove the nipple and you will see.
    Ex plug
    Clean
  5. Rob McMillan United States
    Ohio, USA
  6. Rob McMillan United States
    Ohio, USA
    Hey JP2. Will check that out. Think I had the nipplemoff recently, but appreciate the thought.
    Sidenote - you still want that homemade Pentawrench? I’ve held it for you.
  7. Edward429451 United States
    Canton Ohio
    pasted the generator threads upon reassembly....
    That is yellow brass to yellow brass, so it would not really need sealant. Yellow brass is soft and flows. Tighten until it squeeks and stop. It's always worked for me that way.
  8. snwcmpr
    This may be true, but the 123 requires that the valve be positioned at the "1" of the "123" on the tank for use of the valve with the windscreen on.
