Svea dating ie bubble font and tubular burners
Discussion in 'Stove Forum' started by OMC, Apr 10, 2022.
  1. Nicola Francesco Elia
    Italy
    Ok this particular information is what I remembered. So 1907/8 is still the correct year to indicate the end of the N&W collaboration.
    Thanks,
    Nicola
    PS
    I thought too that the end of publications wasn’t indicating a sure end date for the relationship between N&W
  2. gieorgijewski
    gieorgijewski Subscriber
    @igh371
    O.K. - new source give new possibility...
    but
    Thats newspaper archive is searchable "after 1905" (see upper picture) - and not only in the adverts - but in the EXPORT reports too...
  3. Nicola Francesco Elia
    Italy
    Sorry, just a step back.
    After the 5* above another example pushing the “bubble font” tanks toward the late 1920s.
    To note on this no 15 (from listing in Holland) the absence of Russian side text and same spirit cup and burner of the 5*. For this model too I have no reasons to think that both the burner and the spirit cup are later replacements (just because they are usually found on late 1920s early 1930s models like 25,26, etc.).
    I also recognize a foot style more similar to later models.
    As always still observations.
    44D9200E-BFC9-4F80-9963-3D8470DB4434.jpeg 8FA04021-394D-4E5C-B3C2-48F207233712.jpeg 9360E7AD-9773-4184-9DED-389D9E95FDF9.jpeg 62FA9F59-65FA-498D-B10E-7B8CFDF89C87.jpeg
    Nicola
  4. Nicola Francesco Elia
    Italy
    Ok, a last minute pure speculation:) So take it just as my imaginative thought!
    I have just learned thanks to the last information shared by @gieorgijewski that A. Willander started to market B.A.Hjorth stoves in 1897.
    This 1897 year seems to return quite often.
    The January, 29 1897 advertisement shows the new patented burner by Trassman & Petterssons marketed with the Svea name.
    If Willander started to work with B.A Hjorth in 1897, maybe, just a little before, he was behind the marketing of this new burner with the Svea name.
    I like to imagine that the Svea name is something that belonged to Willander’s creativity and that, after this first failed attempt (that burner appeared only on the patent and on that adv) and after his collaboration with B.A. Hjorth ended in 1904, he repurposed the Svea name with CR Nyberg’s stoves…
    And this would also explain why Nyberg didn’t use the Svea name instead of Victoria in the same years.
  5. Nicola Francesco Elia
    Italy
    Is this adv from 1895 of Victoria 2 the latest trace of Nyberg’s stoves that we have? (dated before 1904).
    I am searching the forum for any info in between these two dates but I had no success. Thanks!
  6. Nicola Francesco Elia
    Italy
    I have just noticed that the 1897 Svea advertisement has been published two times:
    First time on January 19, 1897:
    Second time on February 26, 1897:
    The texts are a little different, on the last one is omitted svea-brannaren.
    Nicola
  7. Nicola Francesco Elia
    Italy
    Always crediting @gieorgijewski for the amazing researches and documents he finds, I am repurposing some of them just to make a linear sequence of events that could be related to the mysterious 1897 Svea stove.
    On November 8, 1897 there was a call from Liedberg & Bäckgreen for defective Record stoves that should have been returned.
    So apparently things were moving fast, in fact the depicted Record stove has already a new burner with classic 4 tubes. So if that was the stove to return that suggests that it was released a little earlier.
    So the lifespan of some burners was very short and of course also that Svea model could have been just a prototype that didn’t have much fortune. So I am pretty sure we won’t found out much more about it.
    Nicola
  8. igh371
    Durham
    Returning to the issue of the tube silent burners and how long they remained in production. I have checked back looking at the examples I have, two Svea No.5s, one Svea 15 with same size tube silent burner as the no.5s, and two No.14s with the smaller size version of the burner burner. All sport the round Sievert tank base stamp and the six line tank side provenance panel as well as the large Cyrillic text side panel which in combination probably places them closer to 1915 than to 1908. The No.s 5 and 15 also have 'Nybergs Patent' marked pump tube caps which I suspect probably fits with that sort of rough time period guestimate. The No.14s, however, have pump tube caps marked 'Svea Sweden' which is a slightly later version of pump tube cap marking. This could place them closer to the date when the Cyrillic tank panel was dropped which would be after 1917
    The difficulty is that, although we can discern these timeline sequences, we have no solid information to fix precise dates to the introduction of the 6 line side panel, the switch from 'Nybergs Patent' to 'Svea Sweden' pump tube cap inscriptions, or for the date when the Cyrillic panel was dropped. That latter presumably occurred after the consolidation of Bolshevik control in Russia, but that could still have been as late as 1921/1922. Consequently I think that it is quite possible that some tube silent burners were produced after the end of WW1, but that may only have been the smaller size version.
  9. Nicola Francesco Elia
    Italy
    @igh371 as I evidenced on catalog 26 from 1915 the tubolar silent burners were fully replaced by the newer 812/813… this doesn’t mean that huge stocks of burners were still used in the next few months/years… so I wouldn’t push the tubular burners to the early 1920, but we can agree that they could have been sold on stoves also in the next few years, 1916,1917…
    All the references we have are not precise or anything, but being able to date with a 2% of approximation is already something.
    Thanks for sharing more detail, I will keep note of everything.
    Nicola
  10. Nicola Francesco Elia
    Italy
    Additionally your description of these models 5 and 15 fits with what I have observed and described in the quoted message above.
    Nicola
  11. gieorgijewski
  12. gieorgijewski
    btw
    Willander 1908
  13. Nicola Francesco Elia
    Italy
  14. Nicola Francesco Elia
    Italy
    @gieorgijewski why do you say late example for that Svea 1?
    Considering the burner and the Willander markings we are clearly in 1905/6…
    We have two patents registrations for that burner, the earlier is late 1905.
    And this burner has been patented before the tubular 804/805… so probably it is the first svea silent burner attempt.
    Nicola
  15. gieorgijewski
    it is not serigraphic as i was writing... mean real older
    it is in perfect design condition
  16. Nicola Francesco Elia
    Italy
    Ok. Remember that we know two Willander logos, 1 pint/2 pints tanks… they are contemporary, they only change because the tank size.
    Additionally, if this really is from 1905/6, earlier than this could be only Willander 0/1 with 800/801 burners…
    Nicola
  17. gieorgijewski
  18. Nicola Francesco Elia
    Italy
    Only this photo I guess… hard to say… I exclude 14 because we have a partial number in a position not compatible with 14:
  19. gieorgijewski
  20. Nicola Francesco Elia
    Italy
    The 12 calls me, I am verifying
