Swiss Military Two Burner
Discussion in 'Military' started by Bom Bom Bom Bom, Aug 26, 2008.
  1. G1gop United Kingdom
    Earth
    I am a bit puzzled. If these are designed for military use, would they not make them so they were happy to run on gasoline?
    Like the British military no2.
    Surely they would use what they had?
  2. gieorgijewski
    gieorgijewski Subscriber
    Hey...
    Could You check distance between center of the both burners and diameter of burner?
  3. Rangie
    Rangie SotM Winner Subscriber
    Absolutely! Except that they would be using them daily for an exercise/operation, after which they would be drained and possibly serviced.
    There was also the infinite availability of spares and spare units for backup.
    For occasional use and with finite spares, its best not to tempt fate.
    Alec.
  4. teckguy_58
    Washington USA
    When I first received mine I fired it up on Coleman fuel and it ran great except there is no way to get the stove to simmer. You can get a good midrange and high. If you run your Swiss double burner for a short time use Coleman types of fuels.
    These stoves are designed to run on auto fuel, but as @Rangie stated when these stove are in use they are run most of the day and then drained and cleaned. If you do want to run this stove on auto fuel here in the US or Canada you will need to find auto fuel without alcohol in it. Here is the link for finding Ethanol free fuel in Canada and the US.
    http://www.pure-gas.org/
    Norman
  5. Lennart F
    Lennart F Sweden Subscriber
    Vänersborg, Sweden
    There has been a big difference in the contents of automotive gasoline from time to time and different countries - US gas tend to leave lots of tar and crystal residues when drying out, some other countries have a high content of spirit and other non-naphta components that make it problematic in pressure burners.
  6. Wim
    Wim Subscriber
    Modern car fuel (petrol) is not only problematic in pressure stoves. We now have fuel with 10% alcohol added. This causes old, steel petrol tanks to rot faster than I can type this, and seals go bump as soon as the fuel touches them. Any old vehicle must use the more expensive fuel (but for how long? Alcohol will also be added to higher octane fuel in the future) or have fuel tanks coated and all fuel lines and seals replaced. Aspen4 would be a far to expensive alternative.
    Best regards,
    Wim
  7. Surveyor
    Fife
    Just found this thread, I have purchased one as well, must get around to firing it up, does anyone have a source in the UK for the pot and stand
  8. Surveyor
    Fife
