Taykit fettle ...heat shield/windshield
Discussion in 'Fettling Forum' started by Remus1956, Nov 2, 2025.
  1. Andrey Sevastopol SotM Winner
    Kiev
    Pharael and Remus1956, thank you for your appreciation of my work. Although I understand that my skills are definitely far from what's required for our work (for example, I don't yet have any soldering skills). Remus1956 asked if the primus stove works. Yes, it works fine with or without the windshield. Perhaps due to an incorrect translation, the phrase "doesn't light" came out instead of "didn't light," meaning it wasn't used to begin with. Although some details were lost.
  2. Pharael
    U.K.
    A flame shot would be good to see.
  3. Remus1956
    Los Angeles California
    @Andrey Sevastopol mine didnt at first. I did a trick that I have fixed coil stoves with and it works sometimes. I go to an auto parts store and get "carburetor cleaner" in an aerosol can. I sprayed and filled the tank about half full and screwed the tank cap on, after putting it to rest in the sun. The tank pressurized and shot all sorts of old gunk out of mine, and used compressed air to push out the rest by putting the air into the tank with a rubber stopper.
    Mine will now leak fuel while I hold it and warm the tank really well.
    I like your windscreen...you should sell them online...people are always missing them..
  4. Andrey Sevastopol SotM Winner
    Kiev
    Pharael, I'll do it soon.
    Remus1956, you had a good idea about cleaning the coil with compressed air. And, of course, the fuel should flow out when gently heated in the palm of your hand. This is a standard feature of coil torches.
    I had an issue with a Fury coil torch, where when I heated the coil and tank with a gas torch, it took 3-4 minutes for it to reach full power. The seal was good and the coil opening was clean. I had to unsolder the tank, replace the wick, and send it off for soldering/assembly. It was a real pain. Now it leaks when heated by hand.
    Regarding sales... In my case, reproducing the missing parts was quite labor-intensive. Therefore, mass-producing this doesn't make sense for me. And there's no demand. In our area, the Taykit is a rare beast.
  5. Andrey Sevastopol SotM Winner
    Kiev
    As promised, here are some photos of the work. Along with Taykit, I launched the Fury, Blitz, and Montagnino. First without diffusers, then with them. The Italian-made Montagnino and Blitz were produced without diffusers. I decided to make my own. Diffuser materials: copper, brass, and stainless steel.
    The Fury has a tarnished finish, darkened by renovations.
    IMG_20251110_184158.jpg IMG_20251110_184158.jpg IMG_20251110_184210.jpg IMG_20251110_184256_1.jpg IMG_20251110_184349.jpg IMG_20251110_184329.jpg IMG_20251110_184403.jpg IMG_20251110_184507.jpg IMG_20251110_184742.jpg IMG_20251110_185333.jpg IMG_20251110_185924.jpg IMG_20251110_185942.jpg IMG_20251110_185942.jpg IMG_20251110_185949.jpg IMG_20251110_190200_1.jpg IMG_20251110_190209.jpg IMG_20251110_190315.jpg IMG_20251110_190335.jpg
  6. Andrey Sevastopol SotM Winner
    Kiev
  7. Andrey Sevastopol SotM Winner
    Kiev
    For the Blitz, I made a spring-loaded plug for the hole, as the standard one (clip-on) doesn't seal properly.
    IMG_20251110_192237.jpg IMG_20251110_192355.jpg IMG_20251110_192542.jpg IMG_20251110_192600.jpg
  8. Andrey Sevastopol SotM Winner
    Kiev
    By the way, the Montagnino and Blitz jars/cases are the same size (+/-).
    Also, with some skill, I was able to fit the curtain inside the Taykit case.
  9. Ed Winskill
    Amazing display of many things previously wholly unknown to me.
    Great post!
  10. Andrey Sevastopol SotM Winner
    Kiev
    I forgot to mention that Montagnino used a pipe from an old, broken Renault 21 Nevada radiator for the diffuser. The internal diameter was the right size.
  11. Pharael
    U.K.
    That is a stunning display you have there. Great work and well photographed. Thank you. :thumbup:
    Pharael.
  12. Remus1956
    I have only heard of the Montagnino...never seen the other ones. Damn... those are nice...
  13. Andrey Sevastopol SotM Winner
    Kiev
    These aren't all the coil stoves I have. I like coil burners, among other things. So, the so-called "stove pox" in my case has metastasized in various directions.:content:
  14. Pharael
    U.K.
  15. Andrey Sevastopol SotM Winner
    Kiev
    Thanks, Pharael.
    The link won't open for me.
    Perhaps I don't have some additional rights.
    But I have instructions downloaded from the internet, specifically from the CCS website.
  16. Christer Carlsson
    Andrey, instructions are only accessible for subscribers.
  17. Andrey Sevastopol SotM Winner
    Kiev
    Christer Carlsson, yes, that's pretty much what I expected.
  18. snwcmpr
    Subscription is reasonable.
  19. Remus1956
