To our norwegian members
Discussion in 'Fettling Forum' started by Alexander, Mar 29, 2008.
  1. shagratork
    Like Keith, I never use steel wool on stoves, no matter how fine the grade.
    I know a number of members who do and although in photographs the cleaned stoves appear fine, in reality there are fine scratches all over the brass which are most easily seen on the fuel tank.
    However . . . . . . . . I also know of members who use fine steel wool and their stoves look fine. To do so they spend a long time polishing out the fine scratches of the wire wool.
    To me it would seem sensible to NOT have the fine scratches in the first place.
    But there again - each to his/her own!
  2. hobowonkanobe
    what about cleaning tin? Any good ideas that wont reduce the amount of metal? It's a tin kettle w/ soot grime on it, want to clean it up but....
    wld white vinigar have an advers affect?
  3. nagant
    just tried a bottle of polish called noxom that did pretty well on my 8r tank. still has rust stains here and there where the rust from the case dripped on it. you can work it wet with a tooth brush, clean it off and repeat till you like it. then wipe some more on and let it dry up a bit and buff with cotton.
  4. Runegutt
    I use Autosol. I find it the best polish sold up here in the cold North.
  5. redspeedster
    redspeedster Brazil Subscriber
    County Durham
