Turner 1161 Redux
Discussion in 'Stove Forum' started by cottage hill bill, Jun 20, 2026 at 10:43 PM.
  1. cottage hill bill
    cottage hill bill SotM Winner Subscriber
    ThIs is the second Turner 1161 I've redone this month. The first was a dark, almost olive green. This one was definitely brown from the factory. It started like this.
    To find a color match I first find a spot of good paint (behind the data plate is almost always a spot of original paint). In this case a spot on the bottom was good. Then I polish it with some rubbing compound to get back as close as I can to the original finish. So here's my target spot after polishing.
    Then I take my possible colors, I had four browns on hand, spray the end of a Q-tip and dab on a spot of paint.
    This is how my four colors came out.
    I picked the second from left as my match. It turned out to be Behr Baronial Brown. This is the first time I've used this paint from Home Depot and I was pleased. Sprayed on well, dried reasonably quickly. As soon as it's dry to the touch I bake it at 170-200 for 30-45 minutes.
    Next came the electrolysis tank for 2-3 days. After the e-tank I rinsed with the garden hose and dried in the N Florida sun. This is fresh out of the e-tank.
    Then I ran it through my sandblaster with medium glass bead. Washed again in hot water then toweled off and blown dry with the air compressor. Then paint. Here's the finished product.
    PXL_20260620_180830661.jpg PXL_20260620_181548218.jpg PXL_20260620_181643937.jpg
  2. hikerduane
    Plumas County, CA
    Realllllyy nice!
