Unidentified Fettling Objects (UFOs)
Discussion in 'Stove Forum' started by Tony Press, Aug 3, 2019.
  1. Tony Press
    These came in a box of Coleman lantern and stove parts. They are NOS.
    I do not recognise them. Any help will be greatly appreciated.
    For size comparison, I placed a No. 5 silent cap next to them.
    Thank you in advance.
  2. teckguy_58
    Washington USA
    Hi Tony,
    This outer cap and screen mesh may be for a Tilley CS56 stove, but I may be wrong.
    Norman
  3. presscall
    @Tony Press
    Yes Tony, as Norman’s suggested, they’re Tilley CS56 components.
    More mesh goes inside the cap to prevent flashback/underburning.
  4. Ed Winskill
    That is a spectacular flame pattern.
  5. OMC
    OMC United States Subscriber
    Thanks Tony, This makes already a few new things learned today.
    John, ditto on Ed's praise of flame shot :thumbup::thumbup:.
    In your wheel house both: to strive for more perfect flame and for perfect images !
    (as i'm not one to post only to praise, please know i do appreciate your effort and consistent excellent results on both fronts within your countless contributions here).
    I post now to thank you for above tip, I won't hold you to it but if it might hold up:
    it never occurred to me that a mesh inside a cap might be solution to consider? for silents w/tendency for underburn ?
    thx omc
    @presscall
  6. Tony Press
    Thanks all.
    I will keep one set of cap and outer mesh, (@Lamp_Doctor has got first dibs on the other cap); but I have a few spare outer mesh if anyone needs one.
    See discussion of same objects here at CPL:
    Can you give me the dimensions of the inner cap/mesh?
    @presscall
  7. presscall
    The Tilley cap hasn’t got the usual inner cap (see the photos below), so mesh inserted in a conventional silent burner cap(s) arrangement would have to go in the narrow space between the two, which I expect would disrupt the gas flow and offer no gain - given that underburn doesn’t happen in a majority of cases and is usually rectified by other means such as replacement caps or cleaning of their interior surfaces. Many gassie caps (certainly Campingaz ones) have internal mesh. They too don’t have an inner cap arrangement.
    I’ll dig the Tilley out. It’s overdue a firing. The dimensions of the mesh though are: length mathematical pi times cap inner diameter; width is the height of the inner wall of the cap. Mesh gauge ‘medium’ (not ‘fine’). I doubt the gauge is critical.
    05F3F590-5972-425C-B6E6-E157726CFD12.jpeg B2F93ADF-98A1-4652-91DE-3AE37688E1F6.jpeg A9416A0A-DB7F-4351-9451-A61F9DF640C5.jpeg 99D27BA8-4481-42AE-B111-93B024E2EE27.jpeg
  8. Tony Press
    Thanks, John.
