Vht paint?
Discussion in 'Fettling Forum' started by intelekt, Jan 22, 2012.
  1. intelekt
    And there was me thinking you were talking about milk ;)
  2. kerry460
    kerry460 Australia R.I.P.
    G,,day that same thought went through my head.
    i might have my occasional "moments" but i am not bad enough yet to paint a trivet with long life uht milk. does someone want to try it as an experiment, might smell when baking it in the oven to cure it!!!!
    HAHAHA good thing i can laugh at myself.
    cheers
    kerry
  3. Cavry
    Cavry Subscriber
    Far N. Ga, USA
    thanks! As I said just wondering. A friend of mine, with more money than I, had his automobile exhaust manifolds porcelainized I suppose that would work, but OH the cost.
  4. geeves
    geeves New Zealand Subscriber
    Christchurch NZ
    Thats not uncommon on hot rods. Have to machine very carefully and allow for the thickness of the coating but it doesnt go blue like chrome and stainless.
  5. kerry460
    uht milk is cheap.
    laugh at my self.
    and you could just let the exhaust bake it
    haha
    kerry
  6. geeves
    Christchurch NZ
    this must be terminal topic drift.
    My comments on the hot rods was for the porcelain coating on exhaust manifolds. There has been a few French and optimus stoves with complete pocelain finishes that are as good now as when they were made.
    I think uht milk would just create lots of smelly smoke.
    Uht paint should of worked for the heat but it lacks resistance to oils and acids that overflow from pots.
  7. kerry460
    i was being sarcastically funny at myself.
    kerry
  8. intelekt
    Update:
    Well I went for it with the plastikote fast dry enamel (thanks John) and my own little tryout too.
    First I wiped the ring with cellulose thinners, next I sprayed it with a black VHT paint, then a coat of plastikote black gloss enamel...
    Today I fired her up and roasted some chestnuts, the paint smelled a little at first like you would expect, then very small bubbles in the hottest areas, these I think just burst and flattened out again.. The pan ring paint was a littles soft to the touch (ouch burnt fingers)...
    But it held well and didn't stick to the bottom of my pan, and now it is cured it should be harder for next time and so on!
    I'm very pleased with the result of this paint and it is still quite glossy too... Overall a fantastic result. :D/ :clap:
  9. lanevitt
    lanevitt Subscriber
    :shock: =;
  10. intelekt
    Hmm what's up Andrew :-k :?:
  11. loco7stove
    loco7stove Subscriber
    I think if i did that ....
    1. My wife would have given me a funny look :-k :D
    2. If the cellulose had ignited i'd be in hospital :shock:
    3. but the glossy finish may have been better than the original colour :D/ :D :thumbup:
    4. As for roasting chesnuts thats just showing off :D/ :D :thumbup:
    Stu :D .
  12. lanevitt
    lanevitt Subscriber
    Sorry Intelekt ... reading your post started odd mental images .... dabbing ones ring with thinners.
    Made my eyes water. Its just my stupid humour.
  13. intelekt
    Lol :whistle:
    I was in "stove" mode when I wrote that :-$ and my sense of humour had been left outside :rage:
    I getcha now ](*,)
    And chestnuts yes O:) I love showing off me nuts lol :p
    They work though in a pan with a sprinkling of water 8)
  14. kerry460
    G,,day i have bead blasted the trivet again.
    this time i painted with an 850 degree celcius stove paint, matt black. still a pressure pack.
    air dry (summer in the sun) for a day. it is currently on the stove with a pan of lead on it.
    seems to be standing up to it.
    very slight burning off close to center of trivet.
    basically only on the inner projections.
    so far i am happy with it.
    i cant tell you a brand, it is sort of no brand.
    cheers
    kerry
  15. kerry460
    forgot to add , no milk involved.
    HAHAHA
    kerry
  16. presscall
    kerry460 said:
    Which is fine and serviceable, but the challenge is to get an authentic/original gloss black or gold finish on a pan ring.
  17. intelekt
    Well I used your technique John with the black gloss fast dry enamel!
    Plus I have also used the brass fast dry enamel by plastikote with the same results :-) top coated with the plastikote clear gloss, which gives a nice look...
    Am I right in thinking that the original colours are gloss brass and black ?
  18. presscall
    Intelekt said:
    That's about it Ade, yes, depending on the brand.
  19. camper52
    Agree with engine block or (better) exhaust manifold automotive paint - only stuff I've seen here (Canada) that can take direct flames !! Comes in red/grey/black/alum colors. But need to follow complex instructions for best result.
    See my post on taking apart my 502 fettleling).
    Gideon
