Why does a roarer burner roar?
Discussion in 'Stove Forum' started by sefaudi, Dec 15, 2022.
  1. sefaudi
    Turkey
    Maybe an old discussion but thought re-study could be interesting.
    (History repeats itself :lol:)
  2. kerophile
  3. kerophile
  4. Blackdog
    Dreaming of snow
    ...To prove its dominance over silent burners!
  5. JustOneQuestion Belgium
    Belgium
    Another, related question: how can stoves be so different?
    Not everything roars the same. Recently, I started playing around a bit with my old Svea 123r. It roars, but it’s nothing compared with the Primus Multifuel I had 20 yrs. ago. That one produced an unbearable eardrum-piercing shriek, a bit like an F-104 Starfighter in low level flight, but less pleasant (I grew up not far from a military airbase).
    I sold it to a guy planning a trip in Mongolia, and bought a Trangia.
  6. kerophile
    The noise output from a stove is directly related to the velocity of the fluid being burnt.
    “Silent” burners have a lower flammable fluid velocity than equivalent “roarer” burners hence the lower sound output.
  7. sefaudi
    Turkey
    Hey George,
    Thanks for the links showing previous discussions.
    But my question is not the noise level comparison. Indeed silents have some noise as well.
    But a roarer burner really roars. It is completely different from silents.
    Any idea?
  8. snwcmpr
    I have a guess.
    It is the turbulence of the flame hitting the plate.
  9. gieorgijewski
    gieorgijewski Subscriber
    It is dificult to me explain in english - but ill try...
    At first
    Sound is the air pressure changes in range 30 hz to 21 khz
    Sources of sounds in roarer burner
    1 nipple jet flowed gas
    2 ignition area constant explosion of gas/oxigen
    3 top of the flame or proper fluctuations on the top flame
    Frequency of sounds
    1 high circa 5 khz
    2 low circa 3 hundrets hz
    3 low circa 150 hz
    WHAT WE HEAR
    source no.3
    Why
    Power of sounds depends on pressure changes
    "There" changes are biggest
    Hard to easy say why flame is not permanently the same on every side of the burner all the time.
    But We must remember burning depends on triangle:
    Temperature -fuel - air where elents are corellated
    Thats give Us dynamic changes of flame haigh
    Extremal example of that is rocket pulsation engine
    Here We have 'compilatio a few not synchronus engins'
  10. itchy
    Thanks @gieorgijewski I like the way you break it down to physics and physiology.
  11. gieorgijewski
    Hm..
    Is the other way to solve problem and do not lost energy for nothing...
    W/o question mark...
  12. SoylentPlaid
    Hola!
    The roaring is due to Kelvin-Helmoltz instability. You basically have the hot, high-velocity exhaust flowing through the cold "stationary" air. The turbulence generated at the interface produces lots of little sound sources at the vortices, thus the "roar".
  13. snwcmpr
  14. Tony Press
    Go to the top of the class, Ken!
  15. snwcmpr
    Dang, lucky guess, and I end up in front of the teacher?
