Couple more 96 vapouriser re-jettings
Diskussion i 'Fettling Forum' startad av presscall, 29 juli 2011.
    25 augusti 2009
    13.944
    Från:
    Proving to myself as much as anything that the technique could work consistently, I had cause to re-jet two '96' stove vapouriser tubes in the one fettling session.
    One was nmp's
    Fire don't panic!
    The other was mine, from a Primus 96 Sport outfit
    Line-up, left to right, Optimus 96 vapouriser in good condition, nmp's vapouriser, Primus 96 Sport vapouriser
    The problem. That's a 0.32 millimetre pricker in the photos. All three would take a 0.23 millimetre pricker, correct for a 96 vapouriser, but only the Optimus one wouldn't take a 0.32mm one, which was a particularly loose fit in nmp's vapouriser
    For the two defective vapourisers, first step was to make the jet holes even larger ...
    ... to fit these brass inserts ...
    ... prepared as featured in this previous fettling topic
    Easy 'drilling' of 0.23mm holes
    One of the inserts in position just prior to brazing
    Brazed and cleaned up. First one ...
    ... and then the second
    Test firing, the vapouriser from the Sport outfit re-united with its stove, nmp's vapouriser tried out on a late-model Primus 96
    Success!
  2. hikerduane
    1 mars 2010
    10.863
    Från:
    Plumas County, CA
    That's really nice. Great job once again.
  3. RonPH
    1 maj 2009
    5.870
    Am really amazed at how all members can come up with such an ingenious way to keep a stove alive. My hats off to you John and thats one for the books (and fettling tutorials).
    Ron
  4. loco7stove
    loco7stove Subscriber
    30 september 2010
    1.394
    HI John
    "You Da Man" 8) 8) 8) Superb as usual :clap: :clap: :clap: :thumbup:
    Stu :thumbup: .
  5. SNOWGOOSE
    19 oktober 2008
    1.783
    Simply Brilliant.
    Rob
  6. mr optimus
    4 oktober 2007
    3.576
    Från:
    Hi John brilliant work and proof that this systeem will work consistently, and that no burner is not repairable no matter how enlarged the jet orafice has become,and i wonder how many of these burners in the past that could have been saved useing this method of repair.
    Another point even the smallest off cut of material is worth saving for example the use of the brass inserts.
    When ever i come across a burner tha has a enlarged jet orafice that can not be peened to the right size,i will put this systeem of repair into use well done there John
  7. Doug L
    Doug L Subscriber
    1 oktober 2010
    1.139
    Från:
    USA
    W O W great post.I feel like i'm in fettle class with your posts.Keep them coming
  8. danta
    10 november 2006
    47
    ---- really fantastic :clap:
  9. RonPH
    1 maj 2009
    5.870
    John, on the clean up portion after brazing, did you sand or file it down? Would like to know so in future I could do the same.
    Ron
  10. presscall
    25 augusti 2009
    13.944
    Från:
    Single-cut file Ron. If the brazing's a bit puddled (blobs) I take a Dremel sanding drum to it just to attack the high spots, then back to the file.
    Finishing's on a buffing wheel.
