This is the package and contents for a radiator attachment for an Australian Companion No. 5 stove. It is new old stock, in its box, but stored pretty roughly for a long time (not by me). Part names are given as they appear in the paperwork. Reflector. Protecting plate. Top ring. This is the folded and packed fire-guard for the reflector (see paperwork below). Glower. Holder (for the glower). As it came out of the box: The rather tattered and incomplete paperwork. This is what it would look like fully assembled. Here is an incomplete Companion radiator (back corner). Similar design (left; not marked with a makers name) and Aladdin (right, Australian made). Cheers Tony
@Tony Press Thanks for posting Tony. Can you tell what the reflector is made of? Also if it isn't to much trouble what is the diameter and depth of the reflector?
Martin The dimensions you asked for are: Diameter: 305mm (it is circular) Depth: 70mm. Cheers Tony @ROBBO55
@Tony Press Thanks Tony. I have two of the stoves plus other pieces and I have been thinking about making the heater to go with one.
@optipri Companion had a licensing arrangement with Sievert so it could be a straight copy. “Manufactured in Australia under authority of A/b Max Sievert Sweden”. Cheers Tony
The instructions that came with this set are here: https://classiccampstoves.com/threads/companion-radiator-instructions.44137/ Cheers Tony
