Enders 9061D. General overhaul
Discussion in 'Fettling Forum' started by Knee, Jun 17, 2025.
  1. Knee
    Poland
    Hi @Piotrek . Thanks . I had to run my imagination a bit and turn on my spatial vision.:)
    As for the paint. I plan to take the stove on a canoe trip for a few days. There will be a good opportunity for testing.
    Greetings
    Stanisław
  2. alnl1996
    alnl1996 Subscriber
    Ontario, Canada
    Amazing job bringing that stove back to new condition. Masterclass .
  3. Knee
    Poland
  4. Oldhenry1 United States
    Puget Sound, WA U.S.A.
    Well done @Knee!!
    You've given me the courage to attempt fettling my own Enders 9061.
  5. Knee
    Poland
    Thanks . I, in turn, was encouraged by other distinguished members of this forum.
  6. Knee
    Poland
    I decided not to start another thread, so I'm posting this here.
    I recently came across a good opportunity. I found a dilapidated Enders stove for very little money. Of course, I didn't hesitate, because I already had some experience in renovating this type of stove. Like the previous one, this one also needed a thorough renovation.
    Here are some photos of the work in progress.
    IMG_20260115_110445539.jpg IMG_20260120_172936089.jpg IMG_20260120_145612329.jpg IMG_20260120_172325851.jpg
    The casing during cleaning.
    The insides needing cleaning.
    Anti-corrosive primer.
    Gray thermosetting paint.
    Since I had already taken everything apart, I also replaced the wick.
    Then I put everything back together and tested it.
    Since I didn't have a funnel, I dug out some ammunition casings and brass parts from my junk to make a funnel with
    a vent.
    IMG_20260205_170241723.jpg IMG_20260205_211653313.jpg IMG_20260205_211740932.jpg IMG_20260205_211827466.jpg IMG_20260205_211611262.jpg IMG_20260205_211911981.jpg
  7. Pharael
    U.K.
    @Knee
    Excellent restoration. Very nicely done. :clap:
    Pharael.
  8. Knee
    Poland
  9. Oldhenry1 United States
    Very well done @Knee!!
  10. Knee
    Poland
  11. ajvuik
    ajvuik Subscriber
    Netherlands
    What is better than having one Enders stove? Having 2, of course. Very nice restoration on both stoves!
  12. Knee
    Poland
    :lol:
    Thanks you very much @ajvuik !
  13. GibsonsRavinePark2
    GibsonsRavinePark2 Canada SotM Winner Subscriber
    Gibsons, BC, Canada
    @Knee Those are two remarkable restorations. I admire your determination to make both stoves not just funtional, but beautiful and unique in their own way.
    Removing the riveted parts for painting must have been quite the task.
    I have a 9061 that needs a new wick and a fuel tank cleaning. Do you have any advice on removing the fuel tube from the tank? Did you use a thread sealant when reattaching the tube?
  14. Knee
    Poland
    Hi @GibsonsRavinePark2
    Thanks for the kind words.
    I saw your last post.
    I see we both took advantage of that excellent advice from the veteran members of this wonderful forum.
    Yes. Taking it apart was necessary to clean it thoroughly before painting.
    To unscrew the fuel line from the tank, you’ll need to heat the connection with a torch.
    First, drain any remaining fuel from the tank and dry it out. You can pour in a little water just to soak the wick. This isn’t necessary if you plan to replace it.
    It’s best to grip the hexagon with the jaws of a vise and heat the connection with a torch for quite a while, periodically trying to loosen the tank by hand, turning it. After a few attempts, it should come loose.
    To seal the thread, I used a cheaper alternative to Loctite high-temperature adhesive. You need to do this fairly quickly, because these adhesives set fast. IMG_20260202_181519974.jpg
    Good luck.
    Stanislaw
  15. Daryl
    Sunny SoCal Grand Terrace
  16. Daryl
  17. GibsonsRavinePark2
    Gibsons, BC, Canada
    Thanks @Knee and @Daryl
    I gathered the tools, rinsed out the tank, tightened the vise, and gave tank a quick turn to get a feel for how tight it was. To my surprise, it spun off with relative ease. Going by the marred hex and the visible thread tape, I will assume this fuel tube has been removed before by a previous owner.
