Good places to buy fuel
Discussion in 'Stove Forum' started by Trojandog, Jul 3, 2013.
  1. snwcmpr
    He obviously defines them differently. I hoped he can clarify his understanding.
  2. Trusty McTrad
    Trusty McTrad Norway Subscriber
    Norway
    On the premise that Jet fuel is the purest kerosene (British: Paraffine, Norwegian: Parafin), I would like to draw your attention back to my earlier mention of BBQ starter liquid, or charcoal lighter fluid (NB: the petroleum based kind, of course, and not the alcohol variety):
    I mentioned this in a previous post, and have since tested this in several stoves, and it is by far the cleanest and purest replacement fuel for kerosene stoves, now that kerosene seems harder to come by and/or more expensive since its decomissioning as a general home heater fuel in many countries. My experience is that it has less odour, but burns as clean and as effective as pure kerosene.
    So I decided to investigate a little, and the facts support the anecdotal evidence from testing:
    Jet A, or common jet fuel, has a density at 15 deg.C. of 0.820 kg/L, and an energy density of 9.8 kWh/L, which means that you would get approximately 5 kWh out of a 1/2 pint stove.
    Jet A-1, which is the jet fuel preferred in colder climates, due to its freezing point of −47 °C (−53 °F) rather than −40 °C (−40 °F) as for Jet A, has a slightly lower density of 0.804 kg/L, and an energy density of 34.7 MJ/L (9.6 kWh/L).
    Now, BBQ starter liquid sits right in between the two, but is closer to the more energy-dense Jet A.
    (In fact, Charcoal lighter fluid, known as LF-1, was used in the Pratt & Whitney J57 engine which powered the Lockheed U-2 aircraft. With an additive to improve thermal oxidative stability it was covered by a military specification and known as Thermally Stable Jet Fuel, JPTS, which has a density of 0.816 kg/L.)
    So, if Jet A is the purest kerosene, then BBQ starter at a third of the price of camping kerosene seems like a good deal, and available everywhere. Also, if it was good enough for the U-2, it is probably good enough for my stoves.
    All the best,
    T
  3. CRAZY CRAB
    I use kerosene as it is cheaper them paraffin, when I can get me hands on it,
  4. Cooler
    Iv just received my order of 10ltr of Husqvarna power 4 to run my petrol stoves on from..
    Husqvarna XP Power 4 Fuel 5 Litre
    Good service at what I think is a reasonable price @ £39 delivered. (UK)
  5. CRAZY CRAB
    I got a small airport up the road from me, got 1gallon of jet fuel, 90p a Lt, put it in a 8 wick stove, the stove cost £7.50, now around £20 plus, it works, but it burns at a higher Temp, will try it on a 96, one day
  6. Ben Hall
    Ben Hall United States Subscriber
    Huntsville, Alabama, USA
    The wife and I were running errands yesterday and one of the stores we visited had charcoal lighter fluid for sale. A half-gallon was about $5 USA, so I figured I'd pick one up to try it out in the stoves. A gallon of undyed K1 kerosene can be found at Home Depot for about $11 a gallon, so it's similar in price to kerosene sold in stores by the container, but has the advantage of being very common and easy to find.
    I can still get kerosene here pretty easily - just bought about 5 gallons of it for about $25 at my local gas station, but it is red dyed kerosene. In the past, it has been of questionable quality. The current batch seems pretty good - burns well in the kerosene stoves.
    Just got done trying it out in my Svea 16 roarer. (SRG: Another Svea No. 16) This Svea 16 is not my best running stove and tends to have a little bit of a yellow flame even when pre-heated and fully warmed up. I dumped out the kerosene from the tank and filled it about half full with the charcoal lighter fluid. Ran very nicely with a completely blue flame and was pretty much odorless. When burning on the pump red dyed kerosene, I do get a little but of odor from the stoves when running.
    Used the stove to cook up some lunch - browned about 3 pounds of ground beef in a cast iron skillet to be made into tacos. Yum! I love a good taco.
    thanks much,
    ben
  7. Ed Winskill
    I've done it backwards; I use K1 kerosene to light charcoal. Mostly because I fire up the briquets only a few times in season, I have lots of kero on hand, and it takes very little.
  8. chocki United Kingdom
    Wolverhampton, United Kingdom
    Ever since I tried Holts Professional Brake cleaner in my white gas (Petrol NOT!) stoves and lamps, I'm a convert, it's even better than Aspen4, and better than Panel wipe in my opinion and cheaper as well and has less smell.
    With that out of the way, here it is for just £12.99 for 5 Ltrs, buy 2 get delivery free.
    I placed an order on Monday evening just before 10 PM and it arrived Wednesday morning.
    Holts HMAI0201A (202A) Professional Brake Cleaner | at Zoro
    Its pure Naptha, nothing else added.
    I now only use this in my Coleman dual fuel stove and lantern and my modern MSR stoves.
    Kerosene or paraffin C1, the cheapest I can get it for around my area is for £7.99 for 4L pre-pac from TFMSUPERSTORE a local farming supplies, agricultural and country store Farm Supplies, Agricultural & Country Stores | TFM Superstore this is a store only purchase but if you live anywhere near Bridgnorth, Penkridge or Newport (Shropshire), then you can pop in and get some.
  9. redspeedster
    County Durham
    Cheers, I buy O1 tool steel from Zoro, so next time I need some I'll add 5ltrs of brake cleaner.
  10. CRAZY CRAB
    £30 plus for 20lts kerro, on e-bay, UK, cannot get it any were else were I live,
  11. chocki United Kingdom
  12. Stu B United Kingdom
    Cumbria
    What’s your thoughts on heating oil I’ve been running my Tilleys and Bialaddin lamps and our two plumbers furnaces on this for a couple of years now with no issues
  13. Oaktree83 United Kingdom
    Very rare indeed, but still exists:
    Paraffin loose purchase today.
    I wonder if there are any more pumps in the country.
  14. Svea106 United Kingdom
    Bedford, UK
    Called called my local 'Harvest Energy' petrol station in Bedford . No paraffin pump but a 4l 'can' is a sensible £8.29 I was told.
  15. Colin Geer
    Scotland, Highlands
    Sensible? For their profit margins maybe! Domestic kero is curently around £1 per ltr so thats more than twoce as expensive.​
  16. Colin Geer
    Scotland, Highlands
    Been using it for roughly 5 or 6 years now with no problems.
  17. Svea106 United Kingdom
    Bedford, UK
    Agreed, but not much choice when buying small quantities.. B&Q want 12 quid for four litres!
  18. gita8947 United States
    NYC USA
    this is useful information
  19. Colin Geer
    Scotland, Highlands
    £12 for 4 ltrs is crazy, but if that's all you can get, they've got you over a barrel!
  20. Oaktree83 United Kingdom
    Managed to load up heating oil for £1.20 last week at a pump. Pump prices tend to be a bit higher than large volume delivery. Sill, way better than the cheapest C1 paraffin drums I've seen.
    Not done a burn test yet, hope it will work both in my lamps and my heater as I expect to use 2-300L this winter.
