Moha 1
Diskussion i 'Stove Forum' startad av Nicola Francesco Elia, 11 maj 2022.
  1. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    Hello,
    I am in the process of restoring this abandoned Moha 1. Being confident that this will be an hard restoration, the first thing I noticed if compared to the other examples available is the absence of the DGRM text embossed on the tank. Bottom plate is plain too.
    How should be dated compared to the ones with DGRM? Later or earlier?
    I am thinking about to replace the pump tube with a traditional one.
    The problem with this one is that to extract the pump tube I had to desolder the NRV valve with the flame going through filler cap. A support that probably was solders to the internal went away too… I don’t know how to put everything back in place, especially that support…
    Any suggestion is welcome.
    Nicola
    47FC8ED3-7FAF-4E26-8B36-C6A802B64EA7.jpeg B3976AC8-FF1D-4371-B771-590112D7971B.jpeg 98365877-197A-414E-8963-39F87B6B1D7D.jpeg 28A5932D-B9E7-4E8F-A151-9A7F02BAD76D.jpeg 2057F160-539C-4E13-A7F9-A1EEF0FA2BD6.jpeg 4982E264-D9F0-42A5-BCDB-E7CDF377A909.jpeg
  2. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    Sorry a typo… “DRGM”.
    Nicola
  3. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    To note, this Moha 1 has removable supports if compared to all the other examples in the gallery.
    Unfortunately one support is completely missing, so I need to get from the stoves cemetery 3 supports that can be adapted.
    Nicola
  4. gieorgijewski
    gieorgijewski Subscriber
    19 april 2013
    4.301
    IF You do that... You destroy main historical value of that example... construction... fact...
  5. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    @gieorgijewski yes I agree in fact I already fixed the original thing, I just used a part from a spare valve to replace the broken one. I also succeed to solder the support… after I tinned the plate and put the pump in place I applied heat from outside the tank untill the solder melt. I have been lucky:
    DA32651A-20C0-454F-B475-B71602D45857.jpeg 88EACE16-6FE3-4970-8305-67C8CC3676A9.jpeg 92E7C3A8-69C4-4B37-BF8E-6213A16C0FDD.jpeg 529ADFD6-DEBE-41C7-89FA-57B97EB363F2.jpeg 7884AD1A-9553-45AE-AC11-C6C552963E48.jpeg 8A73CD12-280D-4039-A194-2B7D57C3C482.jpeg E7A3EB89-949A-48AE-87BF-2F221702E21E.jpeg 82F620B7-AE98-45A1-97AE-595337154A88.jpeg 6C74E290-38C3-4E54-921A-F9FE2B832F09.jpeg
    Nicola
  6. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    Almost there, I need to make one of the missing supports. For the supports holders I used some coming from an old discus. I had a spare burner that should be a good choice for a Moha 1. Pump works perfectly :)
    Nicola
  7. multi-cho
    multi-cho Korea, Republic of Subscriber
    12 september 2014
    354
    Från:
    Korea/seoul
    Hi
    This time, you performed internal surgery. General Hospital Director!
    That is amazing.
    Fortunately, Moha's unusual check valve has been maintained.
  8. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    @multi-cho ahaha thanks :)
    This Moha needed internal, external and aesthetic surgery!
    I had this spare tank in my “trash box”, so I wasn’t expecting much from it…
    The original valve inspection cap was lost and valve itself and all those bits were soldered all together.
    To fix the valve I had to desolder everything and so, in a first moment, I got scared by all those little bits, so I was thinking about replacing pump tube.
    But once everything was cleaned and after a better inspection I found a way to put everything back together.
    I wasn’t expecting such result from my poor skills.
    Tomorrow I will make a glorious post with nice photos and flame shot.
    Nicola
  9. multi-cho
    12 september 2014
    354
    Från:
    Korea/seoul
    @Nicola Francesco Elia
    Than the gallery post
    Attach a photo of Moha's original condition to the unfinished post.
    6badf0e8babd7032df589a1f8105d4095781b62b_20220512182759.jpg eb0299f563879dcaa2d0909da4c923590a3d840b_20220512182750.jpg 99db8aa7c22a51214798ff3a0303cc2339b80ba1_20220512182746.jpg
  10. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    @multi-cho fantastic, thanks! So the burner is very similar to the Moha 0 burner.
    You’re very lucky to have found such a rare and splendid stove!
    Nicola
  11. multi-cho
    12 september 2014
    354
    Från:
    Korea/seoul
    I am attaching one more.
    This is an image I saved in the past. I don't know if those ufo caps are genuine as I don't have an exact catalog.
  12. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    @multi-cho yes this example is in the gallery here, I think it is a Radius burner.
    Nicola
  13. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    Moha 0 should have regular size burner threads, so probably Moha 0 and 1 used the same burner… what changed was only the destination of the stove: house and traveler.
    On this Moha 0 I can recognize in fact a Primus 1 roarer:
    2C2A605F-AF38-4382-AFD8-67A51A7EA507.jpeg 11318DDA-028A-44CA-B8A8-181F809C1CFA.jpeg F45DC967-BCBA-4CCD-AEFB-407A415698A7.jpeg
    Nicola
  14. kerophile
    23 september 2004
    14.341
    Från:
  15. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    @kerophile is exactly as you say, but it is not mine, it is from a listing. I don’t know if that is a post modification or if it originally came as it is.
    Nicola
  16. Nicola Francesco Elia
    13 november 2016
    3.155
    Från:
    Italy
    I correct myself, Moha 0 received and burner size is of a model 0 not 1. So the distinctive Moha 0 and 1 original burners are very similar, but the size is different, at least the riser threads.
    Nicola
