One or two washers nr 5?
Discussion in 'Fettling Forum' started by fjildman, Jul 18, 2023.
  1. fjildman Netherlands
    Netherlands
    Hi,
    I recently got a Primus nr 5. As a start I’m replacing the washers.
    I wonder: do I want two washers to get the spiritcup in place between the rising tube and the burnerhead.
    I mean: on both sides of the cup?
    Thank you!
  2. hikerduane
    Plumas County, CA
    Some stoves require two, some only one, depends on how the spirit cup sets astride the riser.
  3. presscall
    I favour two. It saves discovering one’s not enough on a first firing when kerosene dribbles out.
  4. Scott B
    Scott B Australia Subscriber
    Tasmania
    @presscall
    Or the dreaded vapourised kerosene cloud from under the spirit cup!
    Usually happens just as the burner reaches full flight.
    Can result in a spectacular sooty mess.
    I have been using 2 washers @fjildman
    As John states.
    Regards
    Scott B
  5. hikerduane
    Plumas County, CA
    Some are only designed for one, they ran for many years with one washer, evidenced when fettling the stove.
  6. Tony Press
    Usually, if the spirit dish has a flat surface adjacent to central hole, I fit two washers.
    Some spirit dishes have the hole cut through the curvature of the dish with no extended flat surface, and therefore it is difficult to fit a washer on the underneath side. These are usually found with only one washer on the top surface of the dish.
  7. fjildman Netherlands
    Netherlands
    Thank you for your answers! You’re a great help.
  8. kerophile
  9. fjildman Netherlands
    Netherlands
    I just did. Thank you!!
    BTW: do you still produce and sell washers?
    Kind regards from Fryslân.
  10. kerophile
  11. fjildman Netherlands
    Netherlands
    Thank you. Misunderstanding. Excuse me.
