Optimus 111 - early.
Discussion in 'Optimus No:111 (all variants) + later Hiker & Hike' started by Robert Radcliffe, Aug 7, 2023.
  1. Robert Radcliffe
    Robert Radcliffe Czech Republic SotM Winner Subscriber
    Stockport UK
    @alnl1996 I'm afraid I don't know the answer to that, but my guess would be the white is the earliest. I wonder if the very earliest 111s had the same black bakelite (?) control as the 11.
  2. kerophile
  3. Robert Radcliffe
    Stockport UK
    @kerophile thank you for the link, now I need to track down the earliest 111.
  4. snwcmpr
    That will most likely be a transition from the Optimus 11.
  5. Wim
    Wim Subscriber
    I have an early 111 in a late 11 case. Transition model? Optimus using up old stock?
  6. 69T100C
    69T100C United Kingdom Subscriber
    Seaton Devon.
    Any chance of some photos
  7. Wim
    Wim Subscriber
    Once I find the time to finish fettling. To many other projects (non stove related) demand my attention at the mo.
  8. OMC
    OMC United States Subscriber
    You wondered/recalled correctly (link below).
    Wim, It's likely an example that matches yours will be included in chronological list of 111s (vs "transition" or using up parts).
    comprehensive list Rel 3.1 111s in-sequence 1952-97
    Note 1 if not on that list it is an example of interest to delve into (there, in linked thread), when you get-round-to-it. No hurries, no worries.
    all, note 2 along same lines I do not want to detract from Robert's example, no need to comment on my tidbit, here. thx
    Robert, Back to your example, plenty to compliment/discuss re your FINE early 111 (i never met a 111 i didn't like).
    "I wonder" if that version was... in an "original dark green" ? ...when i consider optimus 111 - mid fifties example.
    THANK YOU
  9. Robert Radcliffe
    Stockport UK
    @OMC ah that's interesting and better still as I have that colour in stock.
  10. Robert Radcliffe
    Stockport UK
    Progress has been slow due to my blast cabinet media needing filtering or changing leading to multiple blockages of the air gun and having to remove several layers of paint. Under the orange exterior and silver interior I found a layer of maroon and under that green.
    Currently my extractor motor has overheated so work has ceased.
    The pot supports had been painted in place and the spanner wasn't even removed.
  11. alnl1996
    alnl1996 Subscriber
    Ontario, Canada
    Now that's progress, keep it coming:thumbup:
  12. PWDolkas
    PWDolkas Subscriber
    Question: is bead blasting to get rid of the paint & rust better than chemical strippers? I would worry about wearing down the embossed lettering. I'm thinking back to the days when I was restoring old bicycle frames, and overdid it once or twice. Is it just a case of being too heavy-handed on the blasting?
  13. snwcmpr
    Glass beads are less abrasive.
  14. Robert Radcliffe
    Stockport UK
    @PWDolkas plenty of choice in media today that won't damage the stove noticeably e.g. walnut shell, corn cob and as @snwcmpr mentions glass beads (which is what I'm using) My next order will be walnut shell to compare.
  15. Robert Radcliffe
    Stockport UK
    I got the blaster working better today and then finished the metal work with scotchbrite wheels.
    Etch primer applied, so I'm now debating whether to return it to green or go blue. I had both colours matched to other stoves by a paint shop.
  16. snwcmpr
    I let each layer cure. Weeks in between layers. Clean/degrease and paint each layer. The Optimus 8 I did turned out great.
  17. Robert Radcliffe
    Stockport UK
    Decided to go green.
    I replaced all the seals and the leather pump. The jet and valve spindle, graphite packing and nut were also replaced.
    Then a test burn...
    Assembled for a quick photo shoot although the paint will be allowed to cure further before the stove is used. I may add a coat of clear lacquer too.
  18. Twoberth
    England
    Very nice!
  19. Robert Radcliffe
    Stockport UK
    A little heat to help the paint cure...:lol:
  20. BagheeraNZ New Zealand
    NZ
    This sir is a thing of beauty
    Thank you for sharing
