Prentiss Wabers
Discussion in 'Stove Forum' started by newlondon695, Oct 11, 2014.
  1. newlondon695
    I have a Prentiss Wabers model #5. Anybody know what year it was made?
  2. jbf
    jbf Subscriber
    Hi, newlondon695. I see this is your first post; welcome.
    I know very little about the Prentiss Wabers but check out the gallery under US made stoves and if you could post some pictures of the stove burner and preheater cup if it has one. It would be very helpful when a more learned member comes along to get an idea of the date when your stove was built.
    thank you
    john
  3. 1966dave
    If Scouterjan stops by...he is really up on PWs. A photo is always helpful.
  4. newlondon695
    Ok thank you I will post some pics
  5. shagratork
    I have adverts for Prentiss Wabers Nos. 8 and 10 from 1929.
    I also have an advert from 1921 where the stoves are not numbered at all.
    So I presume that your No.5 is from the mid 1920s.
  6. newlondon695
    Thank you for finding that information
  7. newlondon695
    Thank you so much
  8. newlondon695
  9. Doc Mark
    Good Evening,
    Your photos are really too small for us to see anything of import. I can send you my email address, and if you send me the photos, as large as you can, I'll post them here in a larger size for you. Let me know, and we'll go from there. Take care, and God Bless!
  10. newlondon695
    Ok I have more pics to send to your email when your ready thank you 695
  11. newlondon695
    More pics I hope this helps.
  12. idahostoveguy
    idahostoveguy R.I.P.
    Hi Mr. Newlondon695,
    Your No. 5 is unusual. It looks like it has a No. 4 burner and tank.
    Here is one example No. 4 that has the long generator that curls over the burner and under:
    Auto Cook Kit No. 4
    I thought these were only typical to the No. 4, but I see that your No. 5 has the same design. It must have been a transitional period since my No. 5 has the straight generator. It could have been leftovers from the No. 4 manufacture that were installed in the No. 5, who knows???
    sam
  13. newlondon695
    That is Little strange did you notice the different spellings on the two stove cook and kook
  14. Doc Mark
    HI, Newlondon,
    Great that you got some bigger photos to post! I have a PW #4, like Sam's, but my spelling is like your #5 "Auto Kamp Kook Kit". This was done as a form of alliteration, and, I think, because it looks "catchy" do spell things that way. My #4 has the extra long generator, which wraps around the second burner, just as yours and Sam's do.
    I note your fuel cap looks oddly different to mine, and to any other I've yet seen. Is there a stump of hose affixes to the air intake part at on top of your fuel cap? If you have some sharper photos of that fuel cap, outside and inside, that would be good to see.
    Thanks, again, for sharing your stove with us, and nice score on your part! Take care, and God Bless!
  15. idahostoveguy
    I believe that may have been a product infringement between Prentiss Wabers and American Gas Machines. I don't know if there was an agreement or, for that matter, a disagreement, between the two companies or not, but at some point, AGM took over or continued with the 'Kamp Kook' in the name of the stove and PW went with Auto Cook Kit some time in 1922 to 1924.
    sam
  16. newlondon695
    Would that make my stove from the early 20's
  17. newlondon695
    1413668308-20141018_100157_resized_opt.jpg |imgRemoved| 1413668450-20141018_095826_Burst01_resized_opt.jpg
  18. idahostoveguy
    Most likely would be 1920 to 1922-ish is my guesstimate before the change in the name of the kit, anyway.
    The top piece of your fuel cap looks like it could have had a hose attachment that was ultimately attached to a pump. These were not rare and came as an accessory to pressurizing the fuel tank. See the post at the link below near the bottom. There are pictures of two different pumps that yours could have come with:
    Prentiss Wabers #2
    Otherwise, the rest of the fuel cap looks original and normal. There should be a small steel or brass ball inside of your fuel cap moving freely around inside. It holds pressure when the tank is filled and will push the ball up holding the air in. If it is in any way dirty, it will not hold air. Clean with carburetor cleaner and it will work once again.
    Thanks for showing us your fuel cap!
    sam
  19. newlondon695
    Thank you again for the information I will try the carb cleaner Happy stove hunting
