Spare parts
Discussion in 'Stove Forum' started by Svend, Feb 15, 2025.
  1. Svend Denmark
    Jutland
    Hi. I inherited a Phoebus Nr 1, I'm trying to get it up and running. It needs new gasket so I can get pressure on.. anyone know where to get new ones, or how you make them yourself..? Svend
  2. Remus1956
    Los Angeles California
  3. Driftwood United Kingdom
    Kent, England
    Buy a sheet of Viton and cut or punch them out.
  4. Blackdog
    Blackdog Canada SotM Winner Subscriber
    Dreaming of snow
    As @Driftwood says, you can make your own- it's easy and especially worthwhile if there may be other stoves to service in the future.
    You will very likely need to replace to tank lid seal- which can be cut with scissors from a sheet of Viton- and the NRV seal or 'pip' (NRV=non-return valve/pump valve). This is easiest to make using a punch which is rotated- either the pen refill in the thread, or a 4.5mm punch with a round body which can be chucked in a drill.
    The NRV assembly should have a lead washer to seal it into the end of the pump tube. This may be reusable or may need a replacement punched from lead or HDPE (thick plastic containers are a good source).
    If you remove the burner two new heat resistant washers will be needed, these are tricker to make at home as suitable material is brittle.
  5. ROBBO55
    Welcome to CCS @Svend
    If you only have 1 stove I would recommend the seal kit from The Fettlebox.
    A tool to remove the NRV can be purchased online but it is basically a steel rod with a 5mm x 5mm slot in the end.
    Lots of info here on NRVs and home made tools.
    Search Results for Query: Nrv | Classic Camp Stoves
