What year is my Optimus 80? How to make a new wick?
Discussion in 'Fettling Forum' started by Edward Curran, Sep 25, 2022.
  1. Doc Mark
    @Edward Curran ,
    Here is a thread that discusses making your own pips for the SRV.
    SRV seals
    One thing about fettling stoves is that you are going to have to invest in some new tools, that you've very probably not seen before. Spending time in the Fettling forum, and reading about the Optimus 80 and the Primus 71, which are almost twin models, will help you learn the information about which you are asking. Take it slow and easy, and spend many hours reading and researching, and you will find all the information you need to make fettling more easy, and with excellent results! Talk later, and God Bless!
  2. bbsteinle
    bbsteinle United States Subscriber
    Spokane, WA USA
  3. Edward Curran
    Edward Curran United States Subscriber
    Portland, OR
  4. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    You can't always just buy the part you need in this hobby. It looks like you are going to have to make your own pip. They can be punched out of a sheet of viton rubber.
    Take a look at some of the links given above and give it a go.
    ....Arch
  5. night_owl
    night_owl Subscriber
    Switzerland
    @Edward Curran : The filler cap shown in your earlier post seems to be the very same Optimus cap that is used on the (nowadays also Optimus made) Svea 123R. Thus, the Fettlebox' 123/123R filler cap seal and safety valve pip set you've already found would very likely be the right one for your Optimus 80 as well.
    To actually exchange the SRV pip you will need a pentagon key. Also, you should definitely understand how the SRV works and what you are doing (as the red disclaimer text on the Fettlebox website implies). A good start may be @Tony Press 's post on disassembling a Svea 123. Apart from the different tank and box/windscreen, a late Optimus 80 and a late (Optimus made) Svea 123 are very similar, so information you can find on CCS when searching for "Svea 123 SRV pip" or the like would apply to your filler cap as well.
    Best,
    Christina
  6. Edward Curran
    Portland, OR
    Thanks for the tips!! Appreciated!!
    From what I can tell I can use a Dremel tool to adapt a star bit to access the SRV.
    Meanwhile I note what looks like a circular seal inside another valve- recessed within the cylinder indicated on the below photo.
    Is there a seal up in there, and what's it called, so I can replace it?
    Incidentally is there a guide outlining the various parts of stove anatomy? This stuff is not clear to a newbie. Screenshot_20231117-092310-368.jpg
  7. Firestarter United Kingdom
    Plymstock Devon United Kingdom
    @Edward Curran You are a subscriber so you can look in the reference library and find https://classiccampstoves.com/threads/optimus-80-spare-parts-in-english.45748/ exploded diagrams and parts lists. I believe there is a graphite seal in there which you do not need to service. If it leaks you tighten the gland nut a little. If you need to remove the spindle you will probably destroy the seal in which case you can replace it with graphite tape available from the fettlebox or possibly obtain a new one from Base-camp.
    Dave
